A1989 (820-00850) Battery not charging, boots only from charger
  • macdude101
    • May 2020
    Got a MacBook Pro 2019 (A1989) (820-00850) that boots fine so long as it's powered from the power adapter.
    On boot into macOS the battery shows as not charging, and needs servicing. Laptop runs slow, benchmarks are all 50% of expected.
    Diagnostics reports a battery issue (PPT006) but also a potential SMC issue (PFM006).
    Battery has 46 cycles, though went un-used for 2 or 3 years.
    Trying to determine if I should go ahead and replace the battery in the hopes that's causing all the issues or if actually it's the other way around and the SMC is causing the trouble and no-charge.
    Any suggestions and similar experiences appreciated!
  • mon2
    • 14255
    Re: A1989 (820-00850) Battery not charging, boots only from charger
    To rule out the battery, order a fresh one from a high rated vendor on Amazon (local to you). Test it and return or keep it, as you wish. Sitting idle for that duration could be the battery.
    • xxsn0blindxx
      • Sep 2014
      • 7
      macdude101 what did you ned up finding with this? I'm in the same boat, trying to decide if it's worth ordering a battery.
      • aminealae
        • Jun 2013
        • 97
        • morocco
        whats news I'm in the same boat
        • mon2
          • 14255
          @aminealae, does your logic board detect the battery? Report the # of charge cycles for this battery? Post more details.
            NVDC charger configuration...
            11-05-2024, 03:28 PM
            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
            Narrow VDC applications where the system power source is
            either the battery pack or the regulated output of the charger.
            This makes the max voltage to the system equal to the max
            battery voltage instead of the max adapter voltage. Operating
            at lower system voltage can improve...
            11-05-2024, 04:43 PM
          • flat-earther
            how to prevent a connected charger from draining battery when not charging?
            by flat-earther
            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
            So the battery is backfeeding the charger and being drained.
            How can I prevent...
            08-07-2025, 01:04 PM
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
            Bauer tool battery pack charging with a HERCULES charger modification
            The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
            Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
            05-06-2023, 12:17 PM
