GL502VMK keyboard not working after liquid spill
  • questore
    • Dec 2015
    • 573
    • csongrád
    Originally posted by questore
    If nobody has an idea why EC is not responding when try to program it, i order a new EC chip
    I have managed to read the EC and its firmware is good.
    I cannot see where is the communication lines between the two IT chips, can someone point me to the right direction, maybe its just a bad resistor.
    • questore
      • Dec 2015
      • 573
      • csongrád
      I have noticed that even when the laptop is turned off the PCH is getting warm (33 Celsius) and Board Power draw is 80 MilliAmps that is s lot for a laptop that is in OFF state.
      Any idea what should i check on PCH lines that could take such power?
      • khaahk
        • Dec 2013
        • 820
        • Estonia
        Communication between the to ITE is via smbdat/clk0.
        I understand that you programmed the 8171 with 56k dump, all that went fine? Read back also fine?
        • questore
          • Dec 2015
          • 573
          • csongrád
          I have read it and it was exactly the same as the 128k I wanted to write so no need.
          As for the 56k keyboard controller... I have tryed 6 different firmware and none of them worked.
          One of the firmwares is a universal gl50x that allready used on different modells before with success.
          • khaahk
            • Dec 2013
            • 820
            • Estonia
            Check the smb clk and data lines for communication when keys pressed, inspect visually. Liquid damage is not always easy to find.
            • questore
              • Dec 2015
              • 573
              • csongrád
              #26
              Never mind. I wanted to check if windows sees the keyboard contoller at all so i have started to install win 10.
              Durring the installation Laptop suddenly smelled funny and turned off.
              1VSUS now shorted to ground and PCH taking 600 MilliAmps. At least I was right that PCH is taking to much power even in off state.
              Lets see what happens after PCH replacement.
              • ictc
                M1 820-0220 A No keyboard and TP after spill liquid on display
                by ictc
                This machine came with a no power after spill liquid (milk) on the display (customer said did't reach the keyboard...).
                On firts attempt I removed oxidation on the jf600 connector and it worked for a week. Thanm the customer complained abot the video turning off after feew minute and than came back to stop again after feew seconds.
                I than took off the board and check for other corrosion spots and found two resistors corroded near the lid detect sensor UR200 that could explain the abnormal behaviour. Replacing the resistors solved the problem. At reboot I noticed no...
                05-30-2023, 03:16 AM
              • playit
                ps/2 port keyboard dead ? p5ql pro / ethernet cable light
                by playit
                my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
                my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
                few years back ps2 mouse stopped working, but ps2...
                12-23-2024, 06:05 AM
              • questore
                nvme and wifi error after liquid metal spill
                by questore
                Someone brought me a liquid metal damaged motherboard.
                First I have removed alll liquid metal from the board.
                0,75V_ALW was burned, and had to be removed and I have separated the layers until no short was on the VIN (B+) line and the output is no longer shorted.
                Applying 0,77V on the output with my lab PSU make the laptop caming on and i running windows from USB drive SSD
                There are 2 things that not working.
                1. The WIFI card keeps turning off and on with an error code 43 and 10 abouth every 10 seconds
                2. nvme devices are not detected on either of the 2 slots....
                11-11-2025, 01:16 AM
              • ugamazing
                820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                by ugamazing
                So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                04-10-2024, 08:06 AM
                HP Elite x2 Elite x2 1012 G1 Tablet with Travel Keyboard (ENERGY STAR) Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                This specification for the HP Elite x2 Elite x2 1012 G1 Tablet with Travel Keyboard (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Elite x2 1012 G1 Tablet with Travel Keyboard (ENERGY STAR) boardview and Elite x2 1012 G1 Tablet with Travel Keyboard (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                09-06-2024, 05:30 AM
