GL502VMK keyboard not working after liquid spill
  • questore
    • Dec 2015
    • 526
    • csongrád
    Hi Everyone.
    This nice ASUS GL502VMK 2.1 Board come to me after a liquid damage.
    They replaced the keyboard but still only the power button works. NO damage can be seen around the IT controller.
    Windows showing 2 keyboard devices after all software installation. (HID and ps2 compatible keyboard)
    Anyone had this fault before? What do you suggest?
  • questore
    • Dec 2015
    • 526
    • csongrád
    I have ordered a vertyanov programmer because I have read another forum that this motherboard tends to forget keyboard firmware on any error.
    Until it arrives how can I know that the IC is not dead and need to order another?
    • questore
      • Dec 2015
      • 526
      • csongrád
      Brought a vertyanov EC programmer and reflashed EC from this forum:
      https://www.badcaps.net/forum/troubl...m-solved/page2
      first tryed FW_NK0003000B (56K)
      but tryed then all 4 of them
      flashed a CLEAN ME BIOS.
      Also tryed to flash post #9 from here:
      https://www.badcaps.net/forum/troubl...15#post1538753
      of course only 56k but same result.
      Still... no keyboard working.
      Anyone has idea what to do?
      • mon2
        • 14588
        No personal experience with this but in reading the threads, have you attempted to use a blank EC flash device? Then the main bios will reflash the blank EC device upon first boot.
        • questore
          • Dec 2015
          • 526
          • csongrád
          Im a bit confused, what blank ec device means for you.
          For details: After flashing clean me bios and booting up i have shut down the device and rewrited the 56kb ec.
          • mon2
            • 14588
            The EC has a local flash (bios).
            Then there is a main flash bios chip (higher density).
            Do not write anything inside the EC bios. Only erase the EC bios. When you do this, the main bios will inject the firmware inside the black EC bios. I think you are manually writing EC firmware with your tool? Do not do this.
            • questore
              • Dec 2015
              • 526
              • csongrád
              Yes I rewrite ec bios. How do i erase it?
              • mon2
                • 14588
                Your tool should offer a checkbox or setting to just erase the EC bios. Do not program after erasing the bios. Another idea is to fill the buffer with 'FF' = blank byte values. Then program the EC bios with only 'FF'. These are only ideas as personally do not own this tool..yet.
                • questore
                  • Dec 2015
                  • 526
                  • csongrád
                  Unfortunatelly it only has read and write buttons, but FF filling is crossed my mind but i did not know if its an option. I try it tomorrow and post the result.
                  • mon2
                    • 14588
                    You can download a free hex editor that will allow you to create .hex or .bin files where you can populate with 'FF' (hex).
                    I recall using HxD for Windows which was / is excellent.
                    Suggest to use the tool you have to READ out the contents and create a backup to experiment with. From this READ action, you will know the full length of the flash inside the EC. Then proceed to read / edit inside of the HxD tool and fill it with 'FF'. Save it and then write it back to the EC.
                    https://mh-nexus.de/en/hxd/
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      I beleive only kbd controller 56kb can be flashed from keyboard connector with programmer like SVOD etc and not EC.
                      A blank and new EC gets self programmed on 1st boot on this platform.
                      • questore
                        • Dec 2015
                        • 526
                        • csongrád
                        OK but why the keyboard is not working at all?
                        I could flash the EC itself if I order a 15Pin 0.5mm cable for JDEBUG2 connector and flash it (pre-config on vertyanov is named "GL502VS")
                        should I move on that way?
                        (Sideinfo: Keyboard is also tested with vertyanov and it works fine)
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          I dont think EC programming is an issue here. Yes EC could be programmed with DEBUG connector but i was talking about KBD connector as lot many people try to program the EC from KBD connector and waste there time.
                          No liquid spill/corrossion in kbd connector area? traces all intact?
                          • questore
                            • Dec 2015
                            • 526
                            • csongrád
                            All area seems fine, no corrosion. Maybe a residue under the chip that keeps it from communicating with the EC?
                            • questore
                              • Dec 2015
                              • 526
                              • csongrád
                              On this forum someone solved the issue and carefully looking at the posts i realized that he has been flashed the EC itself and after that he flash the KB 56K.
                              So I have ordered a 15pin cable.
                              Be back with result
                              • questore
                                • Dec 2015
                                • 526
                                • csongrád
                                Another bad news for me
                                Cable arrived but EC is not respoding when try to communicate it on DEBUG2 port.
                                Checked cable connections with multimeter abouth 10 times.
                                How can an EC not respond when the laptop starts fine? Could it be some liquid residue under the IT chip?
                                Should I reheat it with some flux?
                                • questore
                                  • Dec 2015
                                  • 526
                                  • csongrád
                                  None of the pins are shorted to ground and all 15 pins have 3.3V on charger plugged in.
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Never tried programming the EC with DEBUG port on this platform-so no idea what;s wrong here. If you have much doubt about EC firmware, you can replace it with a new one but i'm not very sure it will fix it.
                                    • questore
                                      • Dec 2015
                                      • 526
                                      • csongrád
                                      Could there be that the problem is the cable length?
                                      All of my working cable is 250mm length and this one is aftermarket 400mm. I have read that these are very sensitive signals.
                                      Another thing that is strange to me that on the keyboard connector every KSI have 3.3V and every KSO have 0V. On this one all KSI and KSO have 3.3v is that normal?
                                      • questore
                                        • Dec 2015
                                        • 526
                                        • csongrád
                                        If nobody has an idea why EC is not responding when try to program it, i order a new EC chip
                                        • ictc
                                          M1 820-0220 A No keyboard and TP after spill liquid on display
                                          by ictc
                                          This machine came with a no power after spill liquid (milk) on the display (customer said did't reach the keyboard...).
                                          On firts attempt I removed oxidation on the jf600 connector and it worked for a week. Thanm the customer complained abot the video turning off after feew minute and than came back to stop again after feew seconds.
                                          I than took off the board and check for other corrosion spots and found two resistors corroded near the lid detect sensor UR200 that could explain the abnormal behaviour. Replacing the resistors solved the problem. At reboot I noticed no...
                                          05-30-2023, 03:16 AM
                                        • playit
                                          ps/2 port keyboard dead ? p5ql pro / ethernet cable light
                                          by playit
                                          my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
                                          my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
                                          few years back ps2 mouse stopped working, but ps2...
                                          12-23-2024, 06:05 AM
                                        • ugamazing
                                          820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                                          by ugamazing
                                          So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                                          1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                                          2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                                          04-10-2024, 08:06 AM
                                          HP Elite x2 Elite x2 1012 G1 Tablet with Travel Keyboard (ENERGY STAR) Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                                          This specification for the HP Elite x2 Elite x2 1012 G1 Tablet with Travel Keyboard (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Elite x2 1012 G1 Tablet with Travel Keyboard (ENERGY STAR) boardview and Elite x2 1012 G1 Tablet with Travel Keyboard (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                                          09-06-2024, 05:30 AM
