820-00840 no boot!! A BIG MISTERY
  • phantomEVO
    • Mar 2013
    • 488
    motherboard super clean...i don't know the history..
    i have ppbus_g3h at 13v fluctuating
    20v on both usb ports...
    from power supply, it seems to reboot in loop like you can see her
    https://www.dropbox.com/scl/fi/8urbo...=xlamh0kw&dl=0
    In this video you can see also the motherboard under thermal camera
    after dismantled from the frame,...i don't know what happen: now i have 5v on both ports...ppbus_g3h is 0v (no shorted)
    with battery connected, .ppbus_g3h is 1,3v
    3,3 1,1 1,8 present on both controllers but unstable....like in loop
    display of amp meter power off and then on in loop after 4/5 seconds
    SMC_RST is 3,0v unstable
  • mon2
    • Dec 2019
    • 14362
    Remove all power. Meter in resistance mode.
    Measure the resistance to ground of PPBUS_G3H @ fuse F7000. What is the resistance in ohms?​
    Connect the power adapter.
    Share the voltage to ground of the following:
    PPVIN_G3H_P3V3G3H @ D6905, pin # 3 - stable?
    PP3V3_G3H @ R6999 - stable?
    SMBUS_BATT_SCL ; battery connector
    SMBUS_BATT_SDA ; battery connector
    • phantomEVO
      • Mar 2013
      • 488
      resistance to ground of PPBUS_G3H @ fuse F7000 70K
      PPVIN_G3H_P3V3G3H @ D6905, pin # 34,75 NOT STABLE
      PP3V3_G3H @ R6999 3,4 NOT STABLE
      SMBUS_SMC_5_G3H_SCL 0,430K
      SMBUS_SMC_5_G3H_SDA 0,430K
      • mon2
        • Dec 2019
        • 14362
        Measure the resistance to ground of D6905, pin #3.
        • phantomEVO
          • Mar 2013
          • 488
          I REALLY don't understand
          [URL unfurl="true"]https://www.dropbox.com/scl/fi/gasqw54fwf4bt6udr8mqt/820-00840-2.mov?rlkey=w6a7y1zd9svxbtfqp18bb8mgm&st=py1tnl05&dl=0[/URL]
          pin 3 35k 0,556 in diode mode
          • mon2
            • Dec 2019
            • 14362
            Check this:
            https://repair.wiki/w/MacBook_Pro_A1..._at_20V_repair
            • phantomEVO
              • Mar 2013
              • 488
              you see the video? because sometimes i have (totally random) 20 v, but then after some seconds goes to 0 and then to 5v...
              most of the time i have 5v with the amp meter that reboot it self after some seconds in loop
              ps i have not PM_EN_P1V8S0
              • phantomEVO
                • Mar 2013
                • 488
                i really don't understand!!
                https://www.dropbox.com/scl/fi/xx7fv...=rrq8q06a&dl=0
                • mon2
                  • Dec 2019
                  • 14362
                  https://logi.wiki/index.php/CD3215_Bootup_Sequence
                  • phantomEVO
                    • Mar 2013
                    • 488
                    what should i check ?
                    • mon2
                      • Dec 2019
                      • 14362
                      Everything. Start at the top of the checklist.
                      • phantomEVO
                        • Mar 2013
                        • 488
                        UPC_XA_GATE1 4,8V
                        UPC_XA_GATE 0V
                        UPC_XB_GATE1 10,9
                        UPC_XB_GATE2 6,3V​
                        SMC_RST (i've found SMC_RESET_L) is 0V and not 3,3
                        • mon2
                          • Dec 2019
                          • 14362
                          Ok. Confirm (without power) that the resistor @ R7072 is present on the board. Confirm the resistance of this part is ~1k ohms. Confirm that you have the same incorrect voltage @ R7072, pin #1.
                          re: your post # 7 - yes, you do have this in the design.
                          Label is PM_EN_P1V8S0.
                          Click image for larger version  Name:	PM_EN_P1V8S0.png Views:	0 Size:	55.2 KB ID:	3592434
                          • phantomEVO
                            • Mar 2013
                            • 488
                            Ok i've done some magic (rehot both usb controller) and now i have (i hope) 20v rocksteady on both ports, but no boot
                            You see here the amp meter
                            [URL unfurl="true"]https://www.dropbox.com/scl/fi/ul599f9jp9thqpuf9i8k0/820-00840-4.mov?rlkey=gd8pla7y94c4mi9ers4zbjrrv&st=cfhcinkb&dl=0[/URL]
                            • phantomEVO
                              • Mar 2013
                              • 488
                              ppbus_g3h is 13v
                              pp3v3_s5 and pp5v_s5 presents
                              • mon2
                                • Dec 2019
                                • 14362
                                Good job on the 20v fix.
                                Attached.
                                • phantomEVO
                                  • Mar 2013
                                  • 488
                                  sorry mon, what should i do now with all those schematics^
                                  • mon2
                                    • Dec 2019
                                    • 14362
                                    The numbers inside each circle indicate the order of the sequencing performed by this board. Starting with (1) - the 5 volt rail is supplied by the power adapter, etc. You will need to review each step to determine at which point the board stops to boot. From your posted videos, the board is power cycling. You reach ~500mA and then power cycle.
                                    You can review the board with a thermal camera to determine if you have a shorted part that is forcing an excessive current draw - perhaps even a shorted capacitor.
                                    You can do the same by removing all power -> measure the resistance to ground of each power inductor. Each inductor is linked to a power rail. If there is a shorted part, the local regulator will power down that rail.
                                    Perhaps an issue with the local bios.
                                    Perhaps a missing part on a local current sense loop circuit which will force the local rail to power down again.
                                    The posted diagrams will also help.
                                    • phantomEVO
                                      • Mar 2013
                                      • 488
                                      this is what i see under thermal camera
                                      https://www.dropbox.com/scl/fi/szvcn...=zbqta7c5&dl=0
                                      • phantomEVO
                                        • Mar 2013
                                        • 488
                                        all_sys_pwrgd is 3,3 and then goes to 0
                                        • NolesFan
                                          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                          by NolesFan
                                          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                          10-24-2024, 06:36 PM
                                        • Takeatry
                                          Yet another Samsung QLED Boot Loop
                                          by Takeatry
                                          Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                          10-04-2024, 02:57 PM
                                        • blaster_
                                          Samsung UE49MU6105K - boot loop, horizontal lines
                                          by blaster_
                                          Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                                          Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                                          06-22-2022, 05:19 PM
                                        • torchzack
                                          Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                          by torchzack
                                          Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                          I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                          Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                          08-28-2023, 07:42 AM
                                        • No Lan
                                          [Macbook pro A1708] [Boot loop] [Trackpad ?]
                                          by No Lan
                                          Hey everyone,
                                          Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                                          Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                                          Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                                          05-24-2025, 03:09 PM
