MSI GF63 MS-16W21 - Black Screen LCD - Working HDMI
  • mavaro
    • May 2017
    • 32
    • Polska
    I have an MSI GF63 laptop with a MS-16W21 motherboard on my table, and there is no image on the LCD screen. However, when connected via HDMI, the image displays correctly.
    Voltages on the EDP 40-pin connector pins:
    3pin = 012V,
    5pin = 1.75V,
    6 pin = 5V,
    7 PIN = 3.3V
    32 PIN = 2.2V
    33 - 36 PIN = 3.3V
    38-40PIN - 19V
    PU21 - MP2143
    1 - 5V
    2 - 5V
    3 - 3.3V
    4 - 0V
    5 - 3.3V
    6 - 0V
    7 - 0.6V
    8 - 3.3
    Help me please
  • mavaro
    • May 2017
    • 32
    • Polska
    Help me please
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Measure voltage on pin14/15 of edp connector.
      Is it dimm display issue or no display issue on internal screen?
      The measurement given are for PU21 or PU22?
      • mavaro
        • May 2017
        • 32
        • Polska
        EDP
        14 - 0V
        15 - 0V​
        PU21
        Laptop working HDMI
        • mavaro
          • May 2017
          • 32
          • Polska
          I had no way to test the matrix on another laptop, I ordered a new original one for MSI. The effect is the same, no image. The voltage +3V_LCD appears for a moment and drops to 0V
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Dont have the exact boardview/schematic for this model in my database. I beleive PU21 is responsible for generating +3V_LCD. If yes, then there should be a coil nearby PU21 where this +3V_LCD goes.
            Try de soldering this coil and measre resistance to GND on both sides of this coil( on the IC side+ on the edp side).
            Share the values.
            • mavaro
              • May 2017
              • 32
              • Polska
              IC 7.5kohm / edp 8kohm - replacement MP2143 , +3V_LCD will appear for a moment and then drop to 0
              • mon2
                • Dec 2019
                • 14801
                What are the full topside markings on PU22 (drives the power rail to the LCD)?
                Post a clear pic of this part. Have only the boardview file for this model. Would you have a full schematic?
                If you are also missing the image then there may be a mux (multiplexer) that steers the data from the graphics processor to HDMI or this target LCD.
                • mavaro
                  • May 2017
                  • 32
                  • Polska
                  I am posting a photo - PU21 system, as a precaution I did a PCH reflow, programmed the BIOS.
                  • mavaro
                    • May 2017
                    • 32
                    • Polska
                    the signal EDP_OD# is from the KBC kb9548qf2 BGA chip, shouldn't it be 3V?
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      De-solder PL20 and inject 3V on edp connector side from another source. Do you get display?
                      • noipi
                        • Aug 2017
                        • 85
                        • Singapore
                        Check also the lid sensor at the back of your display connector which is U24 that gives +3valw and backlight on
                        • mavaro
                          • May 2017
                          • 32
                          • Polska
                          On the PL20 coil I have a constant voltage of 3.3V all the time, on U24 I have +3VALW, U21 pin 4 - BL-ON 0V.
                          • Ryan.man
                            by Ryan.man
                            02-04-2025, 12:23 PM
                          • reformatt
                            by reformatt
                            07-31-2025, 08:37 PM
                          • smic717394
                            by smic717394
                            07-25-2024, 10:16 AM
                          • DeXXter
                            [Question] Acer nitro 5 image on HDMI without screen
                            by DeXXter
                            Hello, I was offered an acer nitro 5 motherboard (i5 10300h + gtx 1650) and I have this little question, is it possible to just connect this motherboard through hdmi and have picture and access the bios without the drivers and windows? because I don't have the display for this one.
                            I had an old acer with ryzen 2500u without display that was able to access the bios using hdmi only, but with this intel model I don't know. So it would be appreciated if someone knows if this is possible.
                            Thanks!
                            09-25-2025, 09:48 PM
                          • Chrissygizmo
                            by Chrissygizmo
                            02-10-2025, 12:33 AM
