MSI GF63 MS-16W21 - Black Screen LCD - Working HDMI
  • mavaro
    • May 2017
    • 28
    • Polska
    I have an MSI GF63 laptop with a MS-16W21 motherboard on my table, and there is no image on the LCD screen. However, when connected via HDMI, the image displays correctly.
    Voltages on the EDP 40-pin connector pins:
    3pin = 012V,
    5pin = 1.75V,
    6 pin = 5V,
    7 PIN = 3.3V
    32 PIN = 2.2V
    33 - 36 PIN = 3.3V
    38-40PIN - 19V
    PU21 - MP2143
    1 - 5V
    2 - 5V
    3 - 3.3V
    4 - 0V
    5 - 3.3V
    6 - 0V
    7 - 0.6V
    8 - 3.3
    Help me please
  • mavaro
    • May 2017
    • 28
    • Polska
    Help me please
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Measure voltage on pin14/15 of edp connector.
      Is it dimm display issue or no display issue on internal screen?
      The measurement given are for PU21 or PU22?
      • mavaro
        • May 2017
        • 28
        • Polska
        EDP
        14 - 0V
        15 - 0V​
        PU21
        Laptop working HDMI
        • mavaro
          • May 2017
          • 28
          • Polska
          I had no way to test the matrix on another laptop, I ordered a new original one for MSI. The effect is the same, no image. The voltage +3V_LCD appears for a moment and drops to 0V
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Dont have the exact boardview/schematic for this model in my database. I beleive PU21 is responsible for generating +3V_LCD. If yes, then there should be a coil nearby PU21 where this +3V_LCD goes.
            Try de soldering this coil and measre resistance to GND on both sides of this coil( on the IC side+ on the edp side).
            Share the values.
            • mavaro
              • May 2017
              • 28
              • Polska
              IC 7.5kohm / edp 8kohm - replacement MP2143 , +3V_LCD will appear for a moment and then drop to 0
              • mon2
                • Dec 2019
                • 14154
                What are the full topside markings on PU22 (drives the power rail to the LCD)?
                Post a clear pic of this part. Have only the boardview file for this model. Would you have a full schematic?
                If you are also missing the image then there may be a mux (multiplexer) that steers the data from the graphics processor to HDMI or this target LCD.
                • mavaro
                  • May 2017
                  • 28
                  • Polska
                  I am posting a photo - PU21 system, as a precaution I did a PCH reflow, programmed the BIOS.
                  • mavaro
                    • May 2017
                    • 28
                    • Polska
                    the signal EDP_OD# is from the KBC kb9548qf2 BGA chip, shouldn't it be 3V?
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      De-solder PL20 and inject 3V on edp connector side from another source. Do you get display?
                      • noipi
                        • Aug 2017
                        • 69
                        • Singapore
                        Check also the lid sensor at the back of your display connector which is U24 that gives +3valw and backlight on
                        • mavaro
                          • May 2017
                          • 28
                          • Polska
                          On the PL20 coil I have a constant voltage of 3.3V all the time, on U24 I have +3VALW, U21 pin 4 - BL-ON 0V.
                          • Ryan.man
                            by Ryan.man
                            02-04-2025, 12:23 PM
                          • reformatt
                            by reformatt
                            Yesterday, 08:37 PM
                          • smic717394
                            by smic717394
                            07-25-2024, 10:16 AM
                          • Chrissygizmo
                            by Chrissygizmo
                            02-10-2025, 12:33 AM
                          • spice_disc
                            Vizio TV M50-C1 reboot cycle and static on screen
                            by spice_disc
                            I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                            The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                            09-08-2024, 02:37 PM
