SY8003 instead of SY8003A
This topic has been answered.
  • someonenotyou
    • Feb 2021
    • 61
    • LV
    Hi.
    I have a Lenovo HLS1C_HLS1D LA-L502P board with bad SY8003A DC/DC converter.
    I have a different mother board witch contains SY8003 DC/DC converter.
    Can I use SY8003 instead of SY8003A converter?
    These are the differences -
    • Short Circuit Protection:
      • SY8003: Uses latch-off protection. This means that when a short circuit is detected, the device will shut down and remain off until it is manually reset.
      • SY8003A: Uses hiccup mode protection. In this mode, the device will repeatedly attempt to restart after a short circuit is detected. If the short circuit persists, it will continue to cycle on and off until the fault is cleared.
    • Over-Voltage Protection:
      • SY8003: Has latch-off protection for over-voltage conditions. Similar to short circuit protection, the device will shut down and remain off until manually reset.
      • SY8003A: Does not have latch-off protection for over-voltage conditions. It will continue to operate without shutting down.
    ​Thank you.
  • Answer selected by someonenotyou at 03-06-2025, 10:53 AM.
    mon2
    • 14662
    Based on the shared differences, yes. Keep in mind that if there was a trigger even like over-voltage, this regulator will shut off and only a power cycle of the board will reset the device.
    • mon2
      • 14662
