820-01700 - No power - 20V 0.8A
  • ronaldopdias
    • Jul 2015
    • 93
    • United Kingdon
    Hi.
    Got this Mac to repair which has no signs of liquid. No previous history.
    Battery is dead, but I tested with a good working battery and still same.
    PPBUS_G3 - 12.7V
    PP3V3_G3H_RTC - 3.38V
    PP1V8_SLPS2R - 1.8V Cycling.
    T2 is glowing from one side and cycling.
    SLPS2 and Awake is all cycling.
    • LDO0: 0.8V Cycling
    • LDO1: 3.0V Cycling
    • LDO2: 1.2V Cycling
    • LDO3: 1.8V ~ 1.78V
    • LDO_RTC: 1.5V Stable
    • VOUT_RTC: 3.3V ~ 2.69V
    • LDO_CORE: 1.5V
    I've checked all the coils in diode mode and all seems fine.
    U7800 replaced an same issue.
    Revive gets stuck on Installing system.
    Do you think the T2 ic itself is faulty or it still could be software?
    In DFU mode before staring Revive option all the power lines mentioned above are stable.
    As soon as I press Revive or Restore it starts to cycle again.​
  • sajidmirza
    • Aug 2021
    • 24
    • india
    I RECOMMEND U TO FIRST CHK ALL THE CD3217 CHIPS AND COMPONENTS AROUND IT,THEN ALSO CHK U7000 CHIP AND COMPONENTS AROUND.
    • ugamazing
      • Jun 2013
      • 165
      • usa
      Check SSD voltage and inspect for liquid to the power supplies. Common failure on these.
      • ronaldopdias
        • Jul 2015
        • 93
        • United Kingdon
        I replaced the NANDs, CD3217 all 4 and the U7000 and it still same issue.
        Do you think by any change the problem would be on the PCH?
        I could just replace, but I don't have the stencil for this.
        • ugamazing
          • Jun 2013
          • 165
          • usa
          With T2 cycling and glowing, it's probably the culprit in this case. Just wanted to confirm the SSD wasn't the culprit, but now you've confirmed: Bad T2. You can replace it, but you'll need an unlocked donor etc. Also need to make sure you replace with identical model T2 (confirm part number--NOT just pulled from another 01700 as they're not all identical).
          • mon2
            • Dec 2019
            • 14216
            Does PPBUS_G3 - 12.7V not imply that the T2 has booted and is working?
            • ronaldopdias
              • Jul 2015
              • 93
              • United Kingdon
              T2 replaced and the issue still there. Same symptoms.
              • ugamazing
                • Jun 2013
                • 165
                • usa
                I took his "glowing on one side" comment as a T2 short, as that's not a usual thermal print for that chip (and if it's rails are cycling but it *still* heats up quickly enough to catch via thermal?). But yes if ppbus is stable then T2 may actually be fine, but damn what's left? Bad CPU/GPU on these rarely prevents DFU/restore, and he's replaced SSD/T2/PMU/ACEs. Maybe a continuity fault? Maybe start checking your rails on all areas of the board just to be sure, maybe it was bent at some point?
                • mon2
                  • Dec 2019
                  • 14216
                  Remove all power. Meter in resistance mode.
                  What is the exact resistance of the following?
                  PP3V3_G3H_T @ L7660.
                  LDO0
                  LDO1
                  LDO2
                  • ronaldopdias
                    • Jul 2015
                    • 93
                    • United Kingdon
                    • LDO0: 0.195
                    • LDO1: 0.452
                    • LDO2: 0.528
                    • LDO3: 0.610
                    • LDO_RTC: 0.378
                    • VOUT_RTC: 0.391
                    • LDO_CORE: 0.376
                    • PP3V3_G3H_T @ L7660​: 0.392
                    • mon2
                      • Dec 2019
                      • 14216
                      What scale was used on the meter?
                      what are the units of measurement?
                      resistance was requested.
                      • ronaldopdias
                        • Jul 2015
                        • 93
                        • United Kingdon
                        The T2 that I replaced is from same lb model. But I just realize that the original T2 from the board I'm trying to fix is
                        h9hknnnBRumuvr-nlh and the donor T2 is
                        h9hknnn8Kumuvr-nlh.
                        Both board has 1TB storage.
                        Is this relevant?
                        Thanks.
                        • ugamazing
                          • Jun 2013
                          • 165
                          • usa
                          The important number will be the part number, i.e. "339S00467" etc. They MUST MATCH or the board won't power/boot/restore/etc. I believe on the 01700 2.3/1TB boards, they are largely the same but different RAM configurations will use different chips. For boards like the 00850, they had TONS of different T2 chips--maybe 10 or so. Super critical to match part numbers or you'll go crazy.
                          • high-tech
                            Samsung UN55F7050AFXZA ver. TD01 power cycling
                            by high-tech
                            Hello everybody, I could use some help on this one... It's got me guessing...
                            I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                            (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                            (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                            (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                            (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                            9. ground (PWM2) 10. 0.9 volts cycling...
                            09-15-2020, 03:39 PM
                          • usbdevice
                            Acer X223HQ (Version Bbd) on/off-power-cycling
                            by usbdevice
                            Hi all
                            There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
                            https://www.badcaps.net/forum/showthread.php?t=50657
                            https://www.badcaps.net/forum/showthread.php?t=40512
                            The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
                            It's my dad's old monitor. He...
                            08-05-2022, 02:21 AM
                          • dbuergi
                            MacBook A2141 one USB port dead and one power cycling
                            by dbuergi
                            I got a 16inch MacBook Pro showing 5v and 0,3a on the left ports and right side has one power cycling and one showing nothing. The one cycling shows 30c under thermal camera. Surrounding components show no corrosion or any shorts.
                            Any ideas what to check next? The whole board looks clean compared to the other A2141s i saw....
                            04-25-2025, 11:40 AM
                          • valvashon
                            Samsung UN55FH6030: random power cycling
                            by valvashon
                            Samsung UN55FH6030, perfect size for my office and does OTA well but isn't a smart TV. That's OK because I am a TV station engineer and only need it for OTA monitoring.
                            About a month ago it started power cycling itself once or twice a day and now it's nearly continuous once it's been on for a few minutes. Changing channels would really start it cycling and it would take several minutes to stabilize but now it's just doing it almost non-stop without changing channels.
                            Once I disconnected the antenna I found that I could change channels with no issues. My guess is...
                            10-20-2023, 09:59 AM
                          • sewsulle
                            A2179 820-01958 5v 0.345a Cycling
                            by sewsulle
                            Good Afternoon
                            I'm working on an A2179 thats taking 5v and 0.345a from the charger with the board removed.
                            Both ports are cycling and seem to only work on one side. The side that works is different for each port. - I hope that makes sense.
                            I'm not sure if this has to do with the board or the ports.
                            I replaced both CD3217 chips months ago and set the board aside when they didn't fix the issue.
                            U3060 gets hot on the thermal cam and heat cycles with the charger. I checked all pins on U3060 in continuity mode and nothing was short. (I did not check...
                            06-23-2024, 05:11 PM
