820-01700 - No power - 20V 0.8A
    No photos found.
  • high-tech
    Samsung UN55F7050AFXZA ver. TD01 power cycling
    by high-tech
    Hello everybody, I could use some help on this one... It's got me guessing...
    I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
    (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
    (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
    (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
    (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
    9. ground (PWM2) 10. 0.9 volts cycling...
    09-15-2020, 03:39 PM
  • usbdevice
    Acer X223HQ (Version Bbd) on/off-power-cycling
    by usbdevice
    Hi all
    There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
    https://www.badcaps.net/forum/showthread.php?t=50657
    https://www.badcaps.net/forum/showthread.php?t=40512
    The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
    It's my dad's old monitor. He...
    08-05-2022, 02:21 AM
  • dbuergi
    MacBook A2141 one USB port dead and one power cycling
    by dbuergi
    I got a 16inch MacBook Pro showing 5v and 0,3a on the left ports and right side has one power cycling and one showing nothing. The one cycling shows 30c under thermal camera. Surrounding components show no corrosion or any shorts.
    Any ideas what to check next? The whole board looks clean compared to the other A2141s i saw....
    04-25-2025, 11:40 AM
  • valvashon
    Samsung UN55FH6030: random power cycling
    by valvashon
    Samsung UN55FH6030, perfect size for my office and does OTA well but isn't a smart TV. That's OK because I am a TV station engineer and only need it for OTA monitoring.
    About a month ago it started power cycling itself once or twice a day and now it's nearly continuous once it's been on for a few minutes. Changing channels would really start it cycling and it would take several minutes to stabilize but now it's just doing it almost non-stop without changing channels.
    Once I disconnected the antenna I found that I could change channels with no issues. My guess is...
    10-20-2023, 09:59 AM
  • sewsulle
    A2179 820-01958 5v 0.345a Cycling
    by sewsulle
    Good Afternoon
    I'm working on an A2179 thats taking 5v and 0.345a from the charger with the board removed.
    Both ports are cycling and seem to only work on one side. The side that works is different for each port. - I hope that makes sense.
    I'm not sure if this has to do with the board or the ports.
    I replaced both CD3217 chips months ago and set the board aside when they didn't fix the issue.
    U3060 gets hot on the thermal cam and heat cycles with the charger. I checked all pins on U3060 in continuity mode and nothing was short. (I did not check...
    06-23-2024, 05:11 PM
