820-0773
  • guruji
    • Oct 2012
    • 122
    • India
    hey good evening,
    i have this machine 820-0773 which i replaced uf400 cd3217b13 the machine works fine and charges on this port.On the UF500 it power on with this port but it does not charge the battery what strange even more when we plug this port and restart the machine it charges and when you take off the charger and re plug in the adapter it does'nt charge.i suspect the tbt rom bad.UF190 and UF090.
    does anyone have these roms
    thanks
  • CasasElectronics
    • Mar 2019
    • 33
    • Spain
    I have searched over internet and did not find anything about the machine. Is that model correct? Who is the vendor? Acer? HP?
      ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
      This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
      09-12-2024, 03:28 PM
    • CG2
      Janome DC3050 Sewing Machine Pedal Resistance
      by CG2
      OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
      Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
      04-14-2023, 07:53 AM
    • Soulzink
      Samsug washing machine. Power supply DC41-00189a board issue
      by Soulzink
      I am trying to fix a samsung washinmachine power supply main board.
      I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
      Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
      The power supply board reference is the following: DC41-00189a
      I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
      04-19-2025, 06:26 AM
    • rounin
      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
      by rounin
      I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
      🛠 Original Issue
      The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
      04-19-2025, 01:18 AM
    • unimatrix93
      How to stabilize AC voltage to CNC machine
      by unimatrix93
      Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
      I have a CNC machine wired to 3-phase 230V AC.
      It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
      The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
      I contacted the electricity company but they refuse to help me solve this problem.
      So I started to look around for some DIY...
      03-17-2025, 05:52 AM
