Macbook A2289 820-01987A no backlight
  • AlexVG
    • Apr 2022
    • 134
    • SPAIN
    Hi everybody,
    I have Macbook A2289 820-01987A.
    It have had 1.8V short circuit problem that I fixed.
    But after 20 minutes working the backlight went out.
    I found out missing of EDP_BKLT_EN going to U8400 from U0500.
    Ground down level goes from U0500. (I tread to remove R8442).
    The machine starts perfect. I can watch image on the screen with a flashlight, and it works with the external screen.
    Do you have any suggestions what kind of problem I came across?
    Thank you in advance.
  • mon2
    • 13992
    Check the open lid sensor signal line. The trackpad is linked to the open lid sensor so review all interconnected cables.
    • AlexVG
      • Apr 2022
      • 134
      • SPAIN
      Hi Mon2.
      Really thank you for your help.
      Recently I have checked Lid lines.
      I am sure that LID_ OPEN_RIGHT and LID_ OPEN_LEFT have reaction (Hi) (I checked them on U6650)
      Moreover, machine starts when I open the lid.
      But it's quite complicated to check IPD_LID_OPEN on U4802
      and on U8400 with all connectors connected because they are on a back side of the main.
      ___________________________________
      I Have managed to check IPD_LID_OPEN. Not directly, but throw J5100 connector.
      IPD_LID_OPEN is present.
      And now to check EDP_BKLT_EN signal, I need to connect wire.
      • mon2
        • 13992
        Does the backlight now remain always dark?
        • AlexVG
          • Apr 2022
          • 134
          • SPAIN
          Yes.
          But keyboard lights is present (so as it were before)
          • mon2
            • 13992
            As a test, flux and remove R8442 (0R resistor). Then with a piece of wire, mate PP3V3_G3S to BKLT_EN_R. This is the EN pin on U8400 and you are applying a logic '1' onto this enable pin.
            Does this turn on the LCD display backlight? Perform this test only if you are comfortable and with a steady hand. Alternatively, you can solder a piece of wire to do the same.
            • AlexVG
              • Apr 2022
              • 134
              • SPAIN
              Thank you.
              Yes, I thought about it.
              Will try tomorrow.
              It would be good luck if only U8400 damaged.
              • AlexVG
                • Apr 2022
                • 134
                • SPAIN
                I guess I have good luck! It doesn't work!
                (I connected enable signal to 3.3V)
                It most likely means that I have U8400 problem.
                It's not a big problem.
                I have ordered it and waiting for delivery.
                • mon2
                  • 13992
                  Strange because keyboard light is from the same part. Not clear on why the lcd backlight enable signal is not on. If lid is open, the enable should activate.
                  Are you sure the trace to the chip was used to enable?
                  • AlexVG
                    • Apr 2022
                    • 134
                    • SPAIN
                    I meant that I tested it without connected all connectors. Only power supply.
                    Keyboard light presents if the main is in the chassis with all connections.
                    I checked EDP_BKLT_EN​ on the table. I did't know that it need lid open signal.
                    I am waiting for new 48B1A04. Hope that it is a problem.
                    • AlexVG
                      • Apr 2022
                      • 134
                      • SPAIN
                      I am really stuck.
                      I replaced U8400 and Q8400.
                      I got EDP_BKLT_EN​ signal from processor.
                      Q8400 gets voltage drop on resistor R8402, However, voltage on gate of Q8400 does not change (always 12.6V). This voltage should drop to 5V, but it does not.
                      Please help me
                      • mon2
                        • 13992
                        Still working on my beauty sleep but check the resistance of R8402. It is important. Be sure that the backlight pin does pull to 0v, then the gate voltage will drop.
                        As a test, short the gate pin to ground with a piece of wire. Does the backlight turn on with this manual bypass? The mosfet is a p-channel type so gate voltage must be lower to enable.
                        • mon2
                          • 13992
                          Also, test the mosfet as well. It could be defective.
                          Back to counting sheeps..
                          1 Apple customer
                          2 Apple customer…
                          • AlexVG
                            • Apr 2022
                            • 134
                            • SPAIN
                            Hi Montwo.
                            So sorry for the yesterday.
                            Yes, I have replaced Q8400
                            And checked R8402
                            Moreover I tested U8400 in diod test mode and compare with another board.
                            What do you mean "the backlight pin does pull to 0v" ?
                            Where?
                            • mon2
                              • 13992
                              R8402 pin #2 needs to be at 0 v to pull the gate voltage low. Be sure r8402 is of the proper resistance.
                              Can you test the gate pin at ground with a piece of wire?
                              • AlexVG
                                • Apr 2022
                                • 134
                                • SPAIN
                                Hi, Montwo.
                                It were problem in missing BKLT_SCL, and BKLT_SDA going from U8549
                                I have managed to solve it.
                                It's a very interesting A2289 model.
                                Looks like the A1708, but without connected J5100 and J5110 it's not available to start the screen.
                                It makes this board complicated to check.
                                Thank you.
                                • AlexVG
                                  • Apr 2022
                                  • 134
                                  • SPAIN
                                  I am sure you know it, but I found out this article very useful.
                                  https://logi.wiki/index.php/Backlight_Troubleshooting
                                  • baglaivlad
                                    MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
                                    by baglaivlad
                                    Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
                                    Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
                                    01-09-2024, 09:55 PM
                                  • Woodsworth
                                    MacBook Pro A2289 no signs of life except clicking trackpad and charging
                                    by Woodsworth
                                    I hope this is the correct place to post about this device. I originally posted regarding this on iFixit so see the details from that post below:
                                    "I'm hoping someone can give their opinion on the symptoms I'm seeing before I spend any more time and put money into this. I got this MacBook from a customer and after looking at it they decided they didn't want it.
                                    It doesn't turn on and there's no visual signs of life. I have tried resetting the NVRAM, SMC, power cycling, unplugging the battery, using the charger with the battery unplugged. Removed the...
                                    03-15-2024, 04:06 AM
                                  • Zparts01
                                    MacBook A2289 820-01987
                                    by Zparts01
                                    I have a problem I'm hoping someone can help me with. I have an A2289 MacBook that had some liquid damage. After repairing any areas that had corrosion, I was able to get it to show 20v but only .01a on the multimeter. It was consistent on all ports, however I could not get the MacBook to go into DFU mode. I read that I should refllash U4770 and after grabbing the bin from this site I did just that. After soldering the chip back on the board, now I have DFU mode, but the thing is, it won't revive or restore, giving me the error that the device left the DFU state or something to that effect. The...
                                    02-04-2024, 02:07 PM
                                  • saisoni20
                                    MacBook Pro A2289 (820-01987-A) No boot or Display, but boots to DFU and shows status bar only
                                    by saisoni20
                                    Hi everyone.
                                    Recently got MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no Caps Lock, no life except the fan is spinning. But it is able to connect to DFU mode and recognized by another MacBook. I tried to revive but the process ends when the MacBook usually should show an Apple logo with a progress bar and giving me error AMRestoreErrorDomain error 9. I don't have CPU Vcore.
                                    Now I can't able to connect to DFU mode either.
                                    On the USB meter I got 20V/0.9A power draw, and keep looping....
                                    01-29-2024, 08:20 PM
                                  • Grandoni Manuel
                                    MacBook a2289 water damage
                                    by Grandoni Manuel
                                    Hello to all ! I follow you but this is first time write !!
                                    your forum is the best !!
                                    so I’ve a2289 with water damage ! In first time other friend have clean and work ! But after some time stop working !
                                    now, I open the MacBook and I see a lot of corrosion near backlight circuit (I attach some photos about that ) I think the problem is on backlight maybe bcs do strange boot then reboot (attach video ) I change some thing on the circuit like :
                                    q8400
                                    q8401
                                    D8410
                                    and the resistor R8431
                                    if I check PPVIN SOSW LCDBKLT_R I’ve 12,9v
                                    on...
                                    04-03-2025, 06:45 PM
