[help]820-01700 "mistery problem"
  • phantomEVO
    • Mar 2013
    • 500
    Hi to all, i don't know the real history of this board.
    the technician who gave me this board says: "i don't know the history of this board, it not switch to 20v. i have changed ub300 and ub400, than i've discovered to have short on 5v andi i have changed u7650. still 5v not switching"
    so under microscope i've found
    - shorts on rb246,rb401,rb400
    - u7650 (tps51980b) changed with (tps51980A)
    - j6640 melted (maybe some one has reflowed or changed u3100 or u3200?)
    so i've bouth another identical board anche changed all 4 usb controllers respecting the order., installed tps51980b and removed all shorts
    then i've changed u2890
    after this, finally switch to 20v but no boot
    like you see here.
    https://www.dropbox.com/scl/fi/8tssh...=5f5pb348&dl=0
    i'm stuck, i don't know what to check
    i have no 0,9/1,8/2,5 on nand
    i have no shorts around nand...i'm missing something
    those voltage are not present even when i try to restore in dfu
    i've tried to restore in dfu mode with error 4042...
    help!!
  • phantomEVO
    • Mar 2013
    • 500
    1,8 3,3 5 g3s not present
    • mon2
      • Dec 2019
      • 14484
      Measure the resistance to ground of each and every inductor on the board. Each inductor is linked to a power supply. You may have a shorted part on one or more of these power rails.
      • phantomEVO
        • Mar 2013
        • 500
        inductors are all goods....maybe i'm missing some power rail?
        • mon2
          • Dec 2019
          • 14484
          What is the voltage to ground of PPBUS_G3H?
          • phantomEVO
            • Mar 2013
            • 500
            ppbus was shorted!
            PPBUS_G3H_SSD0_SNS and
            PPBUS_G3H_SSD1_SNS
            removed cleaned and reballed u9580! no short anymore on ssd0_sns ! still short on ssd1_sns. reballed u9800 still short. changed with another one from a donor board, short disappeared and ppbus_g3h not in short! amps draw is different but no boot! under camera i see u9080 becoming super hot! but no shorts around...it
            https://www.dropbox.com/scl/fi/k4cfw...=6xjjypd0&dl=0
            • mon2
              • Dec 2019
              • 14484
              If PP2V5_NAND_SSD1 is truly not shorted, suggest to replace U9080.
              • phantomEVO
                • Mar 2013
                • 500
                ok changed u9080 with another one that doesn't warm up.
                ppbus is 12,3 but unstable
                https://www.dropbox.com/scl/fi/02tp4...3iqv4z&dl=0​
                • phantomEVO
                  • Mar 2013
                  • 500
                  PP2V5_NAND_SSD1​ is 68 ohm
                  • mon2
                    • Dec 2019
                    • 14484
                    Do you now have a stable voltage on PP2V5_NAND_SSD1?
                    • phantomEVO
                      • Mar 2013
                      • 500
                      i have no voltage at alll
                      • mon2
                        • Dec 2019
                        • 14484
                        Measure the voltage to ground of the following:
                        SSD_PMU_RESET_L
                        SSD1_VR_P2V5_EN
                        SSD1_VR_P2V5_EN_R
                        PPBUS_G3H_SSD1_SNS
                        • reformatt
                          • Feb 2020
                          • 1439
                          Personally, I wouldn't spend much time on a board that's been fucked with and has this many issues. When I get a board 2nd hand, you can guarantee they have tried to do a DFU with a fault present. This just makes it worse as you now have a T2 that potentially has a corrupted ROM. 68 ohms sounds too low on the NAND's, should be 170 ohms or so at room temp. Check all other NAND power rails as well and compare to the openboardview diode readings.
                          • phantomEVO
                            • Mar 2013
                            • 500
                            i'm an idiot, because i've tried to reprogram t2 rom with a dump from internet.
                            i have had a lot problem writing it with my minipro ....so according to this video,
                            https://www.youtube.com/watch?v=8x15Ye406uY
                            i've bought a ch341 programmer. it seems to program the chip without problem, but now the macbook is DIRECTLY in dfu mode, and trying to reflash it with apple configurator,, it give me everything error 4014 (like it can't exit from dfu). i've tried even with my original dump, wihtout luck..​
                            • phantomEVO
                              • Mar 2013
                              • 500
                              now, i'm waiting t48 programmer....hoping this is only a programming problem....
                              do you have a 100% WORKING T2 ROM DUMP?
                              • mon2
                                • Dec 2019
                                • 14484
                                T2 reflash request was suggested about 50+ posts ago in the original thread.
                                • phantomEVO
                                  • Mar 2013
                                  • 500
                                  i don't understand: could you explain me better mon?
                                  • phantomEVO
                                    • Mar 2013
                                    • 500
                                    you are right, but i would like to fix it!!!
                                    know removing and reflashing soc rom with another dump, i have done big mistake, because now it goes directly in dfu and obviously it doesn't flash corretly t2 give me error 4014.....
                                    i've tried to reflash my original backup, but still the same...directly in dfu
                                    i was wrong before: PP2V5_NAND_SSD1​ 0,43k
                                    • phantomEVO
                                      • Mar 2013
                                      • 500
                                      i think it's normal that it goes in dfu after removing and/or flashing old buck or a dump from internet....problem is that now not having 20v anymore, is quite impossible (for me) to find the original problem...
                                      • phantomEVO
                                        • Mar 2013
                                        • 500
                                        Help 🥲🥲
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • gleniu
                                          Acer Nitro 5 AN517-52-56A5 - won't charge, shorts the AC adapter
                                          by gleniu
                                          I have a problem with Acer Nitro 5 AN517-52-56A5 (motherboard: GH51M LA-K862P Rev: 1A). I was playing TLoU2, which is a rather demanding game, for a few hours, unless the notebook turned off (my guess is that the battery drained to 0%). Now, when I connect the AC adapter, the LEDs are not coming on and the laptop doesn't charge.
                                          It also shorts the AC adapter - I've checked two of them from different manufacturers. Though the AC adapter gives 19,5V as expected, the voltage drops to 0V when I connect it and disconnect from laptop - it comes back to 19,5V when I reset...
                                          05-02-2025, 06:48 AM
                                        • layad
                                          820-01521 ,a1932 stuck on 5.18v 0.22v
                                          by layad
                                          hi there
                                          one of the ports not showing anything on the meter , dead ( one next to screen)
                                          othe port shows 5v , 0.22a
                                          PP3V3_UPC_XB_LDO was shorted on u3200 , changed u3200 . now meter shows the same reading on both ports (5v , 0.22a)
                                          all ldos are present apart of PP1V1_UPC_XB_LDO_BMC , its 0v on both no short
                                          no dfu mode
                                          PP1V8_G3S missing no short
                                          u7650 enable signal is 0v no shorts
                                          any suggestion?
                                          11-12-2022, 10:23 AM
                                        • flusher
                                          Apple MBP16" A2141 820-01700 PMIC power cycles no boot no shorts
                                          by flusher
                                          Bought myself a project thing. Apple MBP16" A2141 820-01700
                                          No shorts, no visible waterdamage.
                                          Dead. no history.
                                          All USBC ports do 20V and charging battery.
                                          If you plug battery/charger PPBUS is 12.6v and all power rails like RTC, 3v3, 5v etc are present. U7800 PMIC all voltages are present APART from PPVCCPRIMCORE_PRIM_REG (not sure if it has to be present at this stage?! resistance is 40 Ohm). SSD 2.5, 0.9, 1.8 are present on both wings. Charger meter shows 30ma or something like this on charged battery.
                                          But what PMIC does is that it power cycles(dropping to...
                                          02-21-2025, 03:12 PM
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
