Lenovo W550S - No Touchpad / Tracker Pad
  • Ritchie_Uk
    Prawnography
    • Mar 2021
    • 185
    • Uk
    • I.T
    Hi There
    I purchased a Lenovo W550S about a year ago, and was really pleased.
    Initially there was intermittent USB connection, which ended up being a bad connection
    There was no TouchPad.
    I ordered a pricey Pad that I was excited about, as I needed a solid machine for myself
    It didn't Work, or should I say that still "No Touch Pad"
    I was gutted, as I got the Laptop really cheaply
    What next please?
    Does anybody have any clues please?
    I have taken the board out, and there and cant see any issues?
    Thanks in Advance
  • rogfanther
    • Jul 2006
    • 458
    • Brazil
    Well, start with checking the flat cables between the touchpad and the motherboard. Are they installed ? Not mangled ? Are they installed in the correct orientation ?
    • pc_okay
      • May 2022
      • 255
      • FRANCE
      Have you check it's not a driver issue ? try in Lenovo UEFI diagnostic utilty if it's available on this model at boot?
      Or with fresh install of windows?
      Could the touchpad you buy be just dead? or like rogfanther connection problem...?
      • Ritchie_Uk
        Prawnography
        • Mar 2021
        • 185
        • Uk
        • I.T
        Hi there Rogfanther and pc_ok
        i replaced the Touch tablet and a new cable was installed
        it still didn’t see it in device manager or even Linux
        Could it be a faulty keyboard?
        it’s such a great Laptop
        Thankyou
        • FriedFred
          • May 2024
          • 143
          Can there be found any voltage on the TP board? Can you find any data traffic on any data line? Is there any data traffic directly on the TP board?
          • Ritchie_Uk
            Prawnography
            • Mar 2021
            • 185
            • Uk
            • I.T
            UPDATE !!
            Hi FriedFred and Folks - I just tested the Laptop after I installed the new Track Pad and Cable.
            It didnt work before, even in Linux
            I uninstalled the Drivers "Cleanly" and Reinstalled them
            All seems to Work now to my surprise !!
            The USB Ports were intermittently disconnecting, but that was solved, by re-soldering and cleaning the ports.
            I am not truly sure why it has started working now, but it is and I will extensively test it in the Field
            But thankyou for the Folks who posted any suggestions
            • Ritchie_Uk
              Prawnography
              • Mar 2021
              • 185
              • Uk
              • I.T
              Hi FriedFred
              I will take some Voltage readings that I can refer to as a document on a working unit.
              Still not sure what fixed it?
              Probably a culmination of all 3 issues
              Track Pad
              Track Pad cable
              Drivers
              • pc_okay
                • May 2022
                • 255
                • FRANCE
                If you are curious and you feel advanturous you can try cross test
                • With old touchpad new câble,
                • old câble New touchpad
                • old câble old touchpad…
                Just for the science 😁
                • Ritchie_Uk
                  Prawnography
                  • Mar 2021
                  • 185
                  • Uk
                  • I.T
                  Hi pc_okay
                  That suggestions "Sounds Logical Captain" Spock Quote
                  I will very tentatively attempt to do that, so I can use the Pad as a Test Pad or throw it away
                  Thanks again
