Macbook M1 A2337 EMC 3598 weird battery charging problem
  • brockauly
    • Jul 2024
    • 6
    • Belgium
    Hi guys,
    If I unplugged the battery and the charger, then plug the battery then the charger, it charges without problem.
    Then if I unplug the charger and plug it back, it won't charge anymore.
    In the first case, main voltage is regulated at ~12.5V and charges the battery.
    After unplugging the charger, main voltage drops to battery voltage at ~11.5V.
    After replugging the charger, main voltage stays at ~11.5V and won't go up to ~12.5V again.
    I found C520A (2.2µ after current sensor from USB-C source) completely burnt and removed it properly. I cleaned around and probed every signal around, I haven't found anything wrong.
    Schematics and brd are available in https://www.badcaps.net/forum/troubl...creen-provisor.
    Any idea ?
    Thanks​
  • mon2
    • Dec 2019
    • 14505
    Remove all power. Disconnect the battery. Meter in resistance mode. Measure the resistance across the battery mosfet at Q5625 (battery mosfet).
    Test:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    Post each measurement. Each measurement should be hundreds of k ohms or higher. Otherwise, the mosfet may be defective.
    • brockauly
      • Jul 2024
      • 6
      • Belgium
      Thank you for your answer. I suppose you mean Q5265 which is indeed the battery mosfet.
      Drain-gate : 12Mohm
      Drain-source : inf.
      source-gate : 3M​ohm
      I have also tried to measure everything accross the double mosfet q5230 and q5240 (difficult because pads unreachable, i measure on surrounding caps thank to the brd. Nothing is shorted.
      • mon2
        • Dec 2019
        • 14505
        Remove all power. Meter in resistance mode.
        Measure the resistance across C5260. Meter probe on each end of this capacitor. We are checking the battery charge current full path resistance. Compare this value against the schematic values.
        Repeat for C5220.
        • brockauly
          • Jul 2024
          • 6
          • Belgium
          C5260 2.2ohm
          C5220 2.5ohm
          resistance of probes when short-circuited : 0.2ohm​
          • mon2
            • Dec 2019
            • 14505
            These looped current resistors are ok and match the schematic values for each.
            Test the dual mosfets @ Q5230 and Q5240 using the resistance check method to confirm they are not shorted.
            You will need to test the resistance across:
            source / drain
            source / gate
            gate / drain
            of each dual mosfet. Be sure to test both mosfets inside the one package. Each should be hundreds of k ohms or higher if the mosfet is ok.
            • brockauly
              • Jul 2024
              • 6
              • Belgium
              All are at least 3Mohm. I couldnt test two out of the four gates because the testpoint is unreachable with my probes. Q5240 pin 1 (CHGR_GATE_Q4) & Q5230 pin 8 (CHGR_GATE_Q2)
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                🛠 Original Issue
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • mkdj
                MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                by mkdj
                About me, my goal and the equipment I (don't) have:
                I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                About my issue and my goal:
                A friend of mine has a MacBook Air M1 A2337 that does not...
                04-03-2025, 08:28 AM
              • Adogabriel100
                where to get trusted CD3217. Problem with A2337 Macbook Air
                by Adogabriel100
                Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
                The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
                09-06-2024, 12:06 PM
              • Skrndelj
                Apple Macbook Air M1 A2337 Trackpad problem
                by Skrndelj
                Hello all,
                I am repairing a Macbook A2337 and i have a problem
                The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
                When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
                I inspected the whole board and everything seems fine.
                Can anyone help me as i didn't fiddle with trackpad...
                06-11-2024, 04:26 AM
              • Patrick501
                Macbook Air A2337 dead at 5V/0,00A
                by Patrick501
                Hey,
                I'm working on a MacBook Air M1. I'm pretty sure the U8100 is not working correctly. But I never had to change it before, so I wanna ask anyone of you guys to confirm (or not confirm) my thoughts on it.
                USB Tester: 5V / 0,00A
                PPBUS_AON: 12,3 V
                PP5v_S2: 0 V no short
                PP3v3_S2_UPC: 0 V no short
                PP1v25_S2: 0 V no short
                PPDCIN_AON_CHGR_R: 5 V
                no enable signals for the S2 rails by the U8100
                both CR3217 (UF400, UF500), are supplied by 5V (Fuses FF200 and FF201)
                PP3v3_UPC0_LDO: 0 V, 0,5V diode mode to gnd
                PP1v5_UPC0_LDO_CORE:...
                11-29-2024, 02:47 PM
