X455LJ REV 3.1 please identify this ic name
  • iamttnien
    • Aug 2023
    • 4
    • Vietnam
    It is missing from the board.
  • mon2
    • Dec 2019
    • 14616
    Attached.
    Click image for larger version  Name:	PD8103.png Views:	0 Size:	3.3 KB ID:	3562348
    • iamttnien
      • Aug 2023
      • 4
      • Vietnam
      Originally posted by mon2
      Attached.
      Thank you very much!
      • iamttnien
        • Aug 2023
        • 4
        • Vietnam
        Attached.
        What boardview software are you using? Thanks a lot.
        • fajfelek
          Macbook Pro M1 a2338 after liquid damage - Need help with identify missing part on trackpad logic board
          by fajfelek
          Hello, First of all thanks you for reading this topic.
          I need your help with identify missing parts on trackpad logic board (661-18430).
          The liquid got into the orange area, but I found that the green area had some parts missing or burnt.
          Please help me with identity parts from blue and red area .
          06-15-2024, 01:41 PM
        • thesame
          DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
          by thesame
          Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
          The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
          02-27-2024, 04:31 AM
        • k-krzych
          Identify board to board connector
          by k-krzych
          Hello, can you help me with an id of this board to board connector, or the the tiny silicon flat wires for replacement? It is found on GPS unit and connects main board with pushbotton small board....
          07-08-2025, 12:32 PM
        • mferna14
          Logic Board 820-01987-A missing PP3V3_S5
          by mferna14
          Hi good Friends., today working on a Macbook Pro A2289, Logic board 820-01978-A. The history was liquid spill, Cleaned & replaced all corroded components & now the logic board shows 20v & .01amp on the meter. Not taking in any amps. Upon trouble shooting I get the required stable voltages 5V, PP3V3_G3H 3.3V but no PP3V3_S5. Checked the schematic, assume that this is generated from U7800. Checked all the Input/Output voltages on this chip. All is fine, except PP3V3_S5 is missing. Resistance from GND to PP3V3_S5 is 146 Kohms. First I need to make sure whether PP3V3_S5 is generated from...
          06-07-2025, 05:07 PM
        • mferna14
          Logic Board 820-00840-A Missing EDP_BKLT_EN
          by mferna14
          Hi dear friends., I am working on a Apple MacBook Pro A1708 , Logic Board 820-00840-A that has no backlight. The logic board powers on fine, but no display. After Checking on the backlight driver chip, I found that the EDP_BKL_EN is missing. And this Power Enable comes from the PCH. So does this means this Logic board cannot be repaired & brought back to life again? The resistance from GRD to the test point of EDP_BKL_EN is around is 0.66M ohms. R8442 (0ohms) is ok. Any suggestion/Tip if any would really appreciate. ​
          07-10-2024, 05:18 PM
