Beginner in need of some guidance
  • X3L
    • Feb 2025
    • US
    I am a newb to chip reprogramming. I purchased a ch341a with the Clip adapter as I accidently bricked the bios on a loved ones Dell Inspiron 15 7548.
    I am now on THE QUEST to understand the fundamentals of this skill set as it is much needed in my family.
    I am now at the point where I am attempting to extract the bios from .exe that i downloaded from the manufacturers website.
    After 4 attempts I am stumped and frustrated. I have never used a Hex Editor and wondering if there is a way for me to do it without the Hex Editor? If not then what do i need to know in order to get this bios chip working again.
    thank you
  • mon2
    • 14814
    Suggest to post the same request inside of the above dedicated BIOS forum. Someone there will be able to assist you with the full details.
    • sparker1
      • Sep 2011
      • 343
      I used to use 7zip. I got this off google.To extract a BIOS from an EXE file using 7zip, right-click on the EXE file, select "Open with 7-Zip File Manager", navigate through the internal structure of the executable to find the BIOS file (usually named something like "bios.bin" or "boot.img"), and then extract it to your desired location; this process may require some exploration within the EXE's contents as the BIOS file might be embedded within other data.​
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • zenius
        by zenius
        12-08-2024, 06:13 AM
      • lucaszmn
        by lucaszmn
        Problem:
        Initial Findings:
        • I concluded that the
        08-12-2025, 03:01 PM
      • Wahaz
        by Wahaz
        10-30-2023, 08:42 PM
      • CanukTuk
        Beginner Tutorial for using RCUnlocker to remove BIOS password?
        by CanukTuk
        Kinda new to this, so hoping you will all give me a bit of a pass.
        I came to this forum because need to remove the BIOS password on an HP EliteBook 850 G1.
        I understand that I need to dumpt the BIOS to a dump file, process the dump file with RCUnlocker, then write the modified BIN file back to tthe BIOS chip.
        Is there a beginner guide anywhere that describes the entire process for doing this?
        I am reallly in the dark regarding which tool or tools are required to extract the BIOS dump file, then write the modified BIN back to the BIOS chip. The guides I have...
        03-24-2024, 02:54 PM
