Presario CQ61 Dead- Not Booting
  • nogger
    • Aug 2010
    • 190
    Re: Presario CQ61 Dead- Not Booting
    Gotcha, thanks. I will have a go at this later today & report back.
    Thank you for your help
    Nogger
    • dj_ricoh
      • 2073
      good luck!
      • nogger
        • Aug 2010
        • 190
        Ok, at the risk of appearing to be a right nugget which one is the BIOS chip ?
        In the good old days they used to have a sticker on them but having just spent 20 minutes going over this m/board & the circuit there's several 8 pin SOIC chips which could be the BIOS. The drawings not a great help either imho
        but i have found a device marked ICH9 Boot BIOS on the drawing (but not located it on the motherboard yet.
        • dj_ricoh
          • 2073
          picture of the mobo will help
          usually the bios on cq its covered with white paint around
          near the mouse pad connecter(under mouse pad)
          or near memory slot
          • nogger
            • Aug 2010
            • 190
            dj_ricoh thanks again.
            I have posted some pics (best i can get with current cam) & i guess then we are talking about the U22 on pic 4 . What a sneaky place to put it. Thanks to that self adhesive aluminium coloure'd shield that was on top of it the type numbers have been erased but as long as i can remove.program & replace the same chip i should be ok.
            Out of interest someone mentioned an EC chip, what is that ? To me EC means Error Checking ?
            Regards
            Graham
            • dj_ricoh
              • 2073
              #26
              did it work?
              • nogger
                • Aug 2010
                • 190
                #27
                Not yet, not been able to read/program it.
                It seems the chip is a cFEON F80-75HCP SPI chip & the eeprom programmer i use (which was a DIY one) only programs the ATMEL 24C series (i2c) chips.
                Looking at he datasheets for the 2 chips they are slightly different in pinout/operation if i read correctly. I think i need something like a Willem programmer. I need to buy a decent programmer anyway so have to see whats available. In the meantime i can't go much further :-(
                Nogger
                • nogger
                  • Aug 2010
                  • 190
                  #28
                  Just found a nice little circuit for programming these chips via an LPT printer port so will have a crack at that tomorrow & report back then.
                  Nogger
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4978
                    • New Zealand
                    #29
                    Regards
                    Graham
                    No, you're thinking of ECC which stands for Error Checking & Correction \ Error-Correcting Code
                    EC means Embedded Controller.
                    Good description here: http://translate.google.co.nz/transl...ded_Controller
                    -David VanHorn
                    • nogger
                      • Aug 2010
                      • 190
                      #30
                      Thanks Agent24, very interesting.
                      Still trying to get this programmer up & running.
                      Regards
                      Nogger
                      • nogger
                        • Aug 2010
                        • 190
                        #31
                        Hi again
                        Well good -ish news. Managed to reprogram the BIOS chip & re-soldered it (after making a copy first of course). The laptop now fires up with lights everywhere etc & video on the display but now it says 'No serial number entered' so if i have read correctly i now have to reprogram the bios with the serial number ? . I will search on here to see if anyone has covered this before but if anyone wants to advise then that would be appreciated.
                        Many thanks to those who responded before , especially dj_ricoh who helped with the BIOS file etc.
                        Regards
                        Nogger
                        • sopik78
                          • Nov 2013
                          • 517
                          • Czech Republic
                          #32
                          use HP DMI tools to set up serial number and mainly MAC address on the board
                          https://www.badcaps.net/forum/showth...highlight=cq61
                          • nogger
                            • Aug 2010
                            • 190
                            #33
                            Just a final update on this problem.
                            Pleased to say it's now back up & running absolutely spot on. Managed to find the DMI tools & entered what was required & my neighbour is now very happy
                            Thanks to all who helped, much appreciated.
                            Nogger
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4978
                              • New Zealand
                              #34
                              Good to hear
                              -David VanHorn
                              • sententia
                                • Oct 2013
                                • 269
                                • Greece
                                #35
                                Nogger,
                                Heads up from me two!
                                Had the same problem. Just a few flashes on the side light when power plugged and then nothing!
                                Rewriting the BIOS solved the problem.
                                However i didn't manage to write the chip with an LPT circuit. Had to buy a programmer.
                                Many thanks!!!
                                • ameixoeiro
                                  • Oct 2014
                                  • 17
                                  • Portugal
                                  #36
                                  i'm having the same problem with two cq61 motherboards. Both just turns on white charger led but none powers on. Tried lots of cq61 bios. And even bios chip have same voltages on same pins. Power Button is having 3.3v but doesn't change when pressed.
                                  Anyone with a possible solution?
                                  Thank'yall
                                  • sopik78
                                    • Nov 2013
                                    • 517
                                    • Czech Republic
                                    #37
                                    Is that intel or amd version?
                                    Do you read 3,3VALW and 5VALW?
                                    Post schematic here.
                                    • ameixoeiro
                                      • Oct 2014
                                      • 17
                                      • Portugal
                                      #38
                                      Yes I checked both the coils and i get 3.3v & 5v.
                                      This is the Intel one.
                                      Thank you.
                                      • pota93
                                        • Sep 2012
                                        • Serbia
                                        #39
                                        Hello, anyone, I have same problem with laptop. I replaced bios chip with chip from another (bad reballing) motherboard and problem not solved. Voltage on bios chip, pin 2 is 3v and charge led lights goes off after 10s. Did I need to reprograming bios chip or...? Sorry for my bad english.
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 4978
                                          • New Zealand
                                          #40
                                          Unless both boards are exactly the same, you will need to reprogram the chip.
                                          -David VanHorn
                                          • tranquility
                                            Asus X515KA not booting. after flashing bios sometimes i come there. but then dead again
                                            by tranquility
                                            hallo,
                                            i have an asus X515KA-EJ058W here.
                                            just both leds white...he battery blinking without battery connected
                                            consuming ~400mA and tries to start but nothing happens but fan spinning if cpu gets warm
                                            if i hold the power button it shuts down and consumes ~30mA i cant spot anything getting warm with thermal....the ec/sio a liiiitle but this is maybe normal beacause it is working ?
                                            power on again is possible but again 400mA then and no picture.
                                            now the really strange
                                            i flashed bios (some version i found on the internet) and resoldered....sometimes...
                                            12-11-2024, 06:47 AM
                                          • farouk_1994
                                            HP Compaq Presario CQ61-417SG
                                            by farouk_1994
                                            Hello everyone please i need dump for HP Compaq Presario CQ61-417SG
                                            10-01-2022, 08:45 AM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                            HP Compaq Presario CQ57-497SG CQ57 Specification for Upgrade or Repair
                                            This specification for the HP Compaq Presario CQ57-497SG can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the CQ57-497SG boardview and CQ57-497SG schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
                                            09-06-2024, 05:27 AM
                                          • Aeisens
                                            Samsung UE50RU7170 not booting /no picture
                                            by Aeisens
                                            Dear all,
                                            My issue is the following:
                                            Tv suddenly started to make Strange things and went out. After disconnecting power and restarting, it tried to start but failed. After each attempt it got worse and worse. Now only the Stdb light is on and it is not booting.
                                            I checked the power supply -> Backlight on when disconnected from mainboard, so I guess Power supply is ok.
                                            Additionally the upper right part of the main-board makes some whistling noise -> probably issue there and therefore issues with booting
                                            Question 1: Where should I start to...
                                            06-24-2025, 03:07 PM
