Dell Inspiron Mini 10 , 17v on power switch
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Re: Dell Inspiron Mini 10 , 17v on power switch
    @mabroukmedal
    thanks I checked Q12 and it is working fine
    • polytek
      • Dec 2013
      • 496
      • TUNISIA
      try this :
      remove rtc battery, dc adaptor and battery, and short dc jack + to - for 1 mn, to discharge
      all the mobo.
      • alibisma
        • Oct 2014
        • 37
        • Saudia
        dell mini 10 17v on/off switch
        hi dear i look the Q12 but there is no volt i change the ene and Q12 ic is good can u help me plz
        • polytek
          • Dec 2013
          • 496
          • TUNISIA
          can you please describe carrefully your problem, i don't understand
          • gbaicu51
            • Feb 2015
            • 29
            hi . i cannot post new tread or search for . for dell 910 mini i have no 3v (bios battery) or 5 v (to usb) . on power button are 17v (wich i understood is ok for dell) , connecting battery i have white power led on , but with no baterry just bling very low power led . any ideeaa please ?
            • gbaicu51
              • Feb 2015
              • 29
              sorry for writing like that .1- on power button , bios battery or usb , i have no power
              2- connecting battery i have white power led on
              3- with no baterry , just blinking very low light power led. dc power is 19v fuse is ok .
              4- there is an orange capacitor in 4v -out 0v but looking ok
              5- connecting an mouse on usb i have just 1second power on it.
              any ideea please what i have to check? i don't have much experience but i'm good student . thanks
              • neha
                • Nov 2015
                • 8
                • India
                #27
                check PU1 PIN1-3.3V and PIN 3 - 3.3V , THIS PIN 3 ACIN signal , SIO 127 PIN 3.3V PRESET , IF NOT PRESENT PU1 PIN 3 82.5K OPEN OR HIGH .
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  #28
                  Original post is 6 years old.
                  • LimesKey
                    Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
                    by LimesKey
                    Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
                    10-17-2025, 05:33 PM
                  • Powderfanupnorf
                    Dell AL440LX power on switch circuit help required
                    by Powderfanupnorf
                    Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
                    So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
                    My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
                    06-24-2024, 01:24 PM
                  • zlr8r
                    Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                    by zlr8r
                    hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                    Ill try and give as much info as I can.
                    Dell Inspiron 17 (7786) Laptop
                    Service Tag: 5J0NHT2
                    Bios: 1.9.0
                    When I received this , it would only flicker on the KB backlight for a second, then off and on.
                    Then it started getting weirder!
                    Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                    12-12-2023, 09:31 PM
                  • Tomylee
                    Dell Inspiron 15 3511 – Won’t power on after plugging in, one chip gets extremely hot
                    by Tomylee
                    I have a Dell Inspiron 15 3511 that stopped turning on after my friend plugged in the power adapter.
                    Here’s what I’ve checked so far:
                    No reaction when pressing the power button (no LEDs, no fan).
                    The power adapter works fine (tested).
                    One chip gets extremely hot as soon as I plug in the charger.
                    The capacitors around that area are not shorted.
                    I’m attaching photos of the board to show the issue.
                    Based on this, what kind of fault or defective component could be related to this overheating?...
                    10-19-2025, 12:24 PM
