Laptop repair solutions, with pictures.
    A new Thread for posting laptop Mb repairs with pictures.
    Let´s make this Thread grow.
    Acer Aspire 5100 MB LA-3081P, no power solution.
    Re: Laptop repair solutions, with pictures.
    I'll help you: don't use .doc files. Not everyone has OR WANTS more proprietary Microshit shit on their computer. Text files with jpegs, please.
      good share btw.
        can someone please convert this to pdf for me thanks
          here u go; personally i prefer normal forum for fix, as here there is no schematic and so on with no test.
            thanks mate
              Just want to share this simple fix on a Samsung netbook regarding power switch. Its applicable on models np-n145, np-n150 and np-n102s etc.
              I used jumpers found on motherboards or hard drive. Cut the the plastic for the jumper to fit. Inserted the jumper and glued it to make it stable. That's it, hope it helps
              check images:
                check images:
                brilliant!!! (gawang pinoy)
                  good job
                    @lezsimply
                    awesome
                      great work man
                        Laptop HP CQ43
                        Problem :
                        White Screen on LCD but OK to Ext Monitor
                        How To :
                        1. Reflow GPU ( Still White )
                        2. Change LCD ( No Display )
                        3. Check Flex Cable ( No Problem )
                        4. Check every signal and voltage on JLVDS1, found that no voltage on +LCDVDD, only 0.20v instead 3.3v. Trace signal at Q8 pin #5 ENAVDD from GPU chipset, voltage is ok 3.3v. That mean no problem with GPU ( sometimes problem from GPU itself ). Suspect on Q7, it's source for +LCDVDD ( my opinion ), replaced with Q155, a quick way before go to scrap mobo . Test it..and yess Compaq logo appears on the screen. Done
                        Forgot take a picture, anyway I attach a schematic for reference. Hope this help anyone who have same problem
                          nice sharing, simple but useful...
                            Laptop: Acer One 14 Z1402 series (NDBU1401_4L)
                            Problem/Symthom : Shorted 19V
                            Likely as common problem for this series, have been receipt 4 mobos which shorted on same point (on december)
                            Culprit: C571 ceramic caps rated 10uF 25V
                              Hp15-u83
                              M/b switches on and instantly gets off.fan spins for 5secs and shuts down.
                              No display
                              found pr303 bad.
                              Replaced. Now mb boots fine
                                Re: Asus X200CA & X200MA.
                                Problem/Sympthom: Intermitt
                                Sometime can power on, at another time it did'nt work.
                                1. Measure on power button, 3.3V have been present - OK
                                2. Already re-flash bios with no result
                                2. Replace ON/OFF button, problem still remain
                                4. Measure resistance on RN (resistor network) that have connected with ON/OFF. the value still good. Try disconnect IO board from main board, then try switch from EC/KBC/SIO pin PWRSW#. The Mobo can turn on without problem.
                                5. Replace RN then solve the problem,
                                6. Test it on some hour. Finally problem solved
                                Still curious...but the point was it works
                                  Very good work meritosari ,but excuse me how you disconnect io ?just remove RN to disconnect?thx
                                    This is about the most common fault I see in this workshop. 0805 10uF 25V ceramics shattering like that, multiple brands. I like it, easy to spot generally, easy to replace.
                                    YouTube Repair Videos - https://www.youtube.com/user/19PLD73
                                    FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
                                      Dell 3521
                                      Problem: no display
                                      1. Missing +VCC_CORE & +VCC_GFXCORE_AXG.
                                      2. Checking PU700 (ISL95833HRTZ) VCCP is missing =1.8v how is connected to +5VS, it should be 5V.
                                      3. Checking +5VS at QZ1 (+5VALW to +5VS), +5VALW present (Drain), Gate (0v), Source (1.8v).
                                      4. Checking B+_BIAS connection ok and present, checking RZ4 resistance broken (56kohm), replace it and finally problem solved.
                                        i love this thread...guys keep up the good work. Will be posting mine soon.
