LA-G07JP led power shortly and goes off
  • ziko07
    • Jun 2021
    • 93
    • Somewhere
    Hi, sch is from LA-G07DP but looks similiar. Problem is that 3/5 v ALW comes when bring power short (1-2 sec)
    From image all marked GREEN is same, 1-2 sec has power
    SPOK colmes 3v3 for short time
    en2= 9v4, its normal and is stady voltage
    en1= 3v3/5v short same as SPOK
    LDO 3v/5V only present short as SPOK
    Pin 11 of IC has stady 9.4v but LDO output also goes iff after 1-2 sec
    EC_ON on pin112 comes also short time and goes low
    Small ic drivers for 3 and 5v alw are SY8286A
    Any help please?
  • mon2
    • Dec 2019
    • 14029
    Remove all power. Meter in resistance mode. Measure the resistance to ground of each and every inductor. Checking for a lower than normal resistance which indicates a shorted part on the board.
    Power adapter is suitable to run this board?
    • ziko07
      • Jun 2021
      • 93
      • Somewhere
      Not seen suspicious resistance, I use to see current consumption bemch lab power but same probl with ori power adapter
      when 35v present than board without battery tajes 450mA and there us oresent cou voltage 1.1v 2 ohases,1.0v, 1 2 to ran, fan spinning but after 3 sec all stops, i noticed if I bend pcb (i connected wire to 5v alw coil) than voltsge comes, like some bad soldering or maybe vias on pcb
      • mon2
        • Dec 2019
        • 14029
        ?? 35v is too high for the logic board. This will nuke at least the dcin MOSFETS.
        • ziko07
          • Jun 2021
          • 93
          • Somewhere
          I'm sure you get point that I meant 3v/5v
          Too much syntax errors on my gsm tastature, sorry
          • mon2
            • Dec 2019
            • 14029
            Actually no, that is why I asked.
            Remove all power. Meter in resistance mode. Measure the resistance between ACP / ACN pins 1&2 directly on the charger IC. Need to confirm the current sense loop resistance is matching the schematic values.
            Touch your meter probes together, this same measurement should be matching the ACP/ACP resistance.
            • ziko07
              • Jun 2021
              • 93
              • Somewhere
              Resistance ACP/ACN is 0.004R, on probe direct 0.001R and drops to 0.000R
              Here is image with coil resistance with GND
              BQ chip write on it BQ25A...
              • mon2
                • Dec 2019
                • 14029
                Full datasheet for the charger IC is posted here:
                https://www.ti.com/lit/ds/symlink/bq...=1736098219535
                Can you confirm if ACDRV is with ~25v at all times or also shutting off after 1-2 seconds?
                Voltage to ground of:
                ACOK
                ACDET
                VCC
                Backup your original EC rom and consider to reflash the same - see post # 40 here:
                https://www.badcaps.net/forum/troubl...ios-dump/page2
                • ziko07
                  • Jun 2021
                  • 93
                  • Somewhere
                  Will check voltages tommorow, also will put your bios even servicer before me tried ,but strange when I bent, press board on ram connectors missing voltage comes again and after 2 sec goes away again. Like some bad solder or pcb
                    • 20709
                    Loose ram slot pins, check them all
                    • ziko07
                      • Jun 2021
                      • 93
                      • Somewhere
                      I couldn't see on microscope, also tried ram in other slot
                      will double check
                      • ziko07
                        • Jun 2021
                        • 93
                        • Somewhere
                        ACOK
                        ACDET
                        VCC
                        Your bin file is 128kB, ori on board is 64kB, its 25X05CL
                        In attachment my ori dump, the big one bios 16Mb servicer already tried 2-3 dumps
                        • ziko07
                          • Jun 2021
                          • 93
                          • Somewhere
                          I give up when bend pcb or press power button all voltages present and goes away after 2 sec
                          tnx for trying help
                          • mon2
                            • Dec 2019
                            • 14029
                            Sounds like a PCB break and/or solder joint dry solder that mates with the flexing. Either way, a tough one to hunt down.
                            • jacobtc
                              PS5 Digital turns on shortly, then off.
                              by jacobtc
                              I have a PS5 digital which shortly turns on (beep, blue light) then off after a second. I measured main rail and no short. All standby voltages are there, taken from here: https://drive.google.com/drive/folde...5Swp5K-NgStDgl
                              Connecting 12V, it draws 300mAh in the first 3 seconds, then 0mAh
                              SSD controller warms slightly when turning on, else nothing
                              Seller described it as intermittent, as it only rarely would turn on. When I received it, it turned in first try, but after turning it off, the symptoms started, and it has not been able to turn...
                              09-06-2023, 03:25 AM
                            • survivalbloke
                              Xbox Series X - crashing to dashboard shortly after launching games
                              by survivalbloke
                              Hey all! I've got a XBOX Series X which came in with the complaint of games crashing to the dashboard after launch. I've tested a few games so far. Red Dead Redemption I observed will load up fine and sit on the menu no problem, but once I actually load into the world, it will not complete the load-in, and crash, stating something about an error must be sent to Rockstar, etc.. Truck simulator seemed to work fine. Minecraft loaded up and zoned into a world, but within a few seconds, it too, crashed to the dashboard. Where are the logs stored? What should I check?​
                              09-18-2024, 11:54 AM
                            • nobbnobb1
                              Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
                              by nobbnobb1
                              Hi guys,
                              Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
                              When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
                              02-03-2022, 11:14 AM
                            • ZixuTech
                              Lenovo Ideapad 700-15ISK shuts down shortly after it starts. Works on battery
                              by ZixuTech
                              Hi Guys, a weird case here.
                              This laptop came with damaged hinges, but no liquid signs.
                              It will loop between battery charging/not charging/charging/... Now the original battery is completely drained it won't turn on with it. The orange light keeps blinking nonstop.
                              I have replaced the battery with a newly charged battery and it turns on but doesn't charge. The orange charging light blinks three times indicating charging issues.
                              I have replaced bq24780S battery charging chip, no difference.
                              With a connected new battery,...
                              04-03-2022, 04:03 AM
                            • darkm4n
                              Lenovo B51-80 green led flashing shortly
                              by darkm4n
                              I am trying to repair a dead Lenovo B51-80 laptop, currently with the battery connected it doesn't power on, it's completely dead, when I connect both battery and charged the green led near the DC input connector stays on but the green led from the bezel stays on for about 2..3 seconds than quickly flashes once than again stays green for another 2..3 secs and the sequence is repeating itself, the laptop does not power on.
                              I did search for a schematic/boardview and could't find any and I don't have much experience with Lenovo laptop boards. I could't find any...
                              03-21-2022, 02:30 PM
