A2681 MacBook Air 13" Short on board question.
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    The board turned on before hand but it was liquid damaged, I was able to fix some of the issue with the board, but the battery wasn't charging and so we replaced a few caps and still no luck, swapped out 4 batteries to see if the batteries were bad, and they were all good batteries after final testing. I checked for voltage at PPBUS_AON and no voltage was present which was odd, so I went ahead and replaced U5200 with a new chip since this has something to do with the charging issue and power issue. Replaced but no life still, so went ahead and look for shorts and found an odd area that is shorted to ground.
    Cap C83B1 is shorted to ground and all the caps on that area, so the caps are not blown, the area in question is PP1V05_S2SW_VDD2H. This is showing up connected to the CPU and I am hoping it is not a failed CPU. Also I did not inject voltage more than 1 Volt into the board to find any shorts on PPBUS_AON but no shorts showed up. I am getting 5Volts and 0.06amps. So what I am confused as what could be the issue? Board looks fine, but I am leaning towards the CPU is failed. This could explain a lot more issues why the battery wasn't charging after replacing the caps that were faulty but donor caps. Board did turn on after we repaired it and now it's dead with a different issue. Any help would be appreciated.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • mon2
    • Dec 2019
    • 14117
    What is the resistance to ground of PPBUS_AON?
    Remove F5200 and then test the voltage to ground of PPBUS_AON again (ISL side).
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 667
      4.00 M ohms and dropping
      sigpic
      • mon2
        • Dec 2019
        • 14117
        Good. Check the resistance across C5220 (with no power).
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 667
          Both Sides of C5220
          9 M ohms and dropping.
          sigpic
          • mon2
            • Dec 2019
            • 14117
            No, check with both probes across C5220. Interested in the full current path resistance of the input side. piernov noted in one post that this is a common fault area.
            • Stephen
              Meow Meow MEOW!
              • Apr 2020
              • 667
              Apologies. 3.2 OHMS
              sigpic
              • mon2
                • Dec 2019
                • 14117
                Also, yes, you are chasing a different rabbit hole now. Earlier, the fault may be the same as what a number of techs have faced about a week ago. After replacing the LCD display, this laptop was unable to charge the battery across 3 units. LCD assemblies from different vendors (XJS & Seven Puppy).
                Do you recall if the laptop was able to power up with only the battery? That puzzle is still being solved. Master Liu noted that he swaps out only the defective LCD with an original LCD from the same model - does not swap out the whole display assembly. That solution works.
                Has this laptop had the LCD assembly replaced?
                Review the notes in the schematic on page 24 as follows:
                • mon2
                  • Dec 2019
                  • 14117
                  3.2 ohms
                  It may be too high. Can you short your meter probes? What is the baseline for your meter for '0 ohms'? This measurement should be 1+1 = 2 ohms.
                  • Stephen
                    Meow Meow MEOW!
                    • Apr 2020
                    • 667
                    Previously, the client came in with liquid damage, I found a lot of shorts on the battery area that needed to be replaced, now those shorts are gone, the screen did turn on before hand and the screen has never been replaced since this is the first time its being worked on. LCD has never been removed or changed so it is the original LCD.
                    The laptop would only power on with power connected, battery would display charging at 1% but never increasing and instantly dying when unplugging power, now the board doesn't turn on anymore. Complicated board I tell you!
                    sigpic
                    • Stephen
                      Meow Meow MEOW!
                      • Apr 2020
                      • 667
                      I do recall the ohms dropping on that line. It did go below 3.0 ohms and steadily dropping across both points. Let me check again
                      UPDATE: ohms dropped to 2.2 steady now.
                      sigpic
                      • mon2
                        • Dec 2019
                        • 14117
                        Which chip was used to replace U5200?
                        Was it sourced from a donor board ?
                        • Stephen
                          Meow Meow MEOW!
                          • Apr 2020
                          • 667
                          489900A6 BGA Power IC Chip
                          this was the exact chip we sourced. Matching
                          sigpic
                          • Stephen
                            Meow Meow MEOW!
                            • Apr 2020
                            • 667
                            Any thoughts Mon?
                            sigpic
                            • mon2
                              • Dec 2019
                              • 14117
                              What is the exact voltage to ground of PPBUS_AON​? 0 volts?
                              Also interested in the voltage to ground for:
                              PPDCIN_AON_CHGR
                              PPCHGR_VDDA
                              PPCHGR_VDDP
                              CHGR_PHASE1_1
                              CHGR_PHASE2
                              PPVBAT_AON_CHGR_REG
                              • Stephen
                                Meow Meow MEOW!
                                • Apr 2020
                                • 667
                                Going to test these points and update you.
                                I do know PPBUS_AON is at 0 Volts.
                                sigpic
                                • Stephen
                                  Meow Meow MEOW!
                                  • Apr 2020
                                  • 667
                                  PPDCIN_AON_CHGR 5.14volts
                                  PPCHGR_VDDA 4.48Volts
                                  PPCHGR_VDDP 4.46Volts
                                  CHGR_PHASE1_1 0 Volts
                                  CHGR_PHASE2 0 Volts
                                  PPVBAT_AON_CHGR_REG​ 0 Volts
                                  sigpic
                                  • Stephen
                                    Meow Meow MEOW!
                                    • Apr 2020
                                    • 667
                                    Update: I found a faulty resistor near U5200. Replaced. Now I am getting 12 volts. Still looking.
                                    sigpic
                                    • Stephen
                                      Meow Meow MEOW!
                                      • Apr 2020
                                      • 667
                                      Now I am at 20 Volts. Ok!
                                      sigpic
                                      • Stephen
                                        Meow Meow MEOW!
                                        • Apr 2020
                                        • 667
                                        Ok so the computer is turning on but now the batteries show 1% but are not charging. I am back to square one with the battery not charging. The LCD has never been replaced and it is the original LCD. I have replaced a few bad caps on the area that affects the battery but nothing still.
                                        sigpic
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • Dylan Jones
                                          MacBook A2681 (Board 820-02862) - UP700 Likely Shorted
                                          by Dylan Jones
                                          I'm a beginner at laptop repair. I bought a MacBook Air A2681 that doesn’t turn on, just for practice. PPBUS_AON and the other always-on voltages are present and look fine. I did some diode mode measurements and got unusual readings (compared to reference values I found online) on LC320 (44mV) and L82D0 (40mV). LC320 corresponds to the PP5V_S2 power rail, and L82D0 to PP1V25_S2.
                                          I injected 1V (current limited to 100mA, the board consumed around 86mA) into PP1V25_S2 to see if anything would heat up, but everything seemed normal. I did the same with 5V (current limited...
                                          06-28-2025, 05:07 PM
                                        • Rezendes
                                          Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                                          by Rezendes
                                          Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                                          I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                                          The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                                          05-10-2024, 02:18 PM
                                        • yuuki47
                                          A2681 M2 MacBook Air Dead Logic Board
                                          by yuuki47
                                          Hello...
                                          My sister purchased an M2 MacBook Air a year and a half ago. While she was using it a week ago, it randomly shut off and no longer powers on. There are no signs of life and not even the MagSafe indicator LED lights up.
                                          We took it to Apple and they disconnected the battery and tried a bunch of stuff before they declared the logic board "brain dead" and quoted us about £567 to replace it. Typical of them...
                                          eBay replacements run about £367 with the Touch ID sensor included.
                                          I did consider to probe the logic board for shorts...
                                          04-13-2024, 06:22 AM
