Macbook Pro 8.2 2015 kernel task 100% and very very slow
  • smic717394
    • Jun 2017
    • 95
    • Spain
    I need a bit of help. I have a Macbook pro end 2011 8.2. I bought it of a customer cheap because it has a bulged battery. I replaced the battery and upgraded the ram 2x8GB total 16GB, and replaced the HDD with a SSD. What happens with this laptop is very strange and I don't know where to begin. The laptop doesn't panic, tha fans run normal even when the kernel is 100%. If I reset the SMS, will run normal for about 30 to 1 hour then the kernel_task goes to 95% and the laptop become unusable. If I reset the sms agail will run again normally for some time. I thought is the battery, so I tried to use it without the battery, same works for some time, then again, I tried the original drive, same, I tried to put back the original ram, same.
    I scanned the ram with mem86, 4 pases and fine, I runned ASD few times and it passes every time. I installed Ventura and Big Sur OLP with the same result. I'm now installing high sierra, and aduring the update, on the first restart I think it was updating the firmware, it was beeping I think 4 short and 3 long or something like this, the led would flash 5 time ( 3 times) then it would start with a larger font, it restarted after the bar loaded, and now is starting again fine. So I´m going to try to install high sierra, but I´m out of ideas.
  • mon2
    • Dec 2019
    • 14563
    Is the trackpad attached? Disconnect it. Does the fan enter high speed? There are sensors inside of the trackpad that may have been impacted by the bulging battery.
    Test with an internet boot / external drive with a clean OS boot. Is it stable with this mode of booting?
    • smic717394
      • Jun 2017
      • 95
      • Spain
      you mean to install from Internet recivery on a external USB drive instead of the internal drive?
      • kevingill
        • Jun 2013
        • 152
        • England
        These are usually symptoms of a corrupt BOOT ROM. You might want to flash it with a cleaned ROM and try again.
        • smic717394
          • Jun 2017
          • 95
          • Spain
          I think the problem might be the battery I bought on Aliexpress. Yesterday I removed the battery and installed clean again High Sierra on a ssd, then updated, and I left it on for at least 6 hours, no problem whatsoever in this time. After All this time, just to verify, I turned off the laptop and reconnect the battery. Apparently was working find, but on the first boot after I connected the battery I noticed something is wrong. It took double the time to load, and I noticed the ambient light sensor isn't working anymore, where before was working. I tried to boot, with the camera connector disconnected, thinking maybe the ambient light has a problem, and this communication I think its handle via i2c, but the same. I disconnected the battery, reset the pram and smc but the ambient light was still no working. I reconnected the original hdd and boot, with the old drive the ambient light was working fine.
          I just reinstall again the OS, I think I will use it few days without the battery just to have a benchmark point, after I will connect the battery. If after the laptop start behaving poorly, I think it's clear the problem is with the battery
          • platinumsteel
            Macbook Air 2015 Booting Very Slow and Stuck on apple Logo 99%
            by platinumsteel
            Hi guys i have my personal MacBook Pro 2015 820-00165 board that was working fine for more than a year and one day stopped working on my original Magsafe charger. It was turning on with my bench power supply. Opened it up and while diagnosing that somehow i ended up with a shorted smc.The line which was shorted was SMC_PM_G2_EN. I removed the SMC and short was gone. So all I had was another working donor board 820-3435 which i used to program it's SMC to 820-00165 using the SMCTOOL By MuertoGB.Took that SMC and use it on my 820-00165 board .And my board started working again. PPBUS_G3H 8.56V....
            03-18-2024, 05:16 PM
          • twonk9098
            Macbook Pro mid 2015 battery required to boot?
            by twonk9098
            I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
            The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
            This model has the newer trackpad which is not clickable when turned off.
            At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
            If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
            12-10-2024, 06:51 PM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • gjlpereira
            MacBook Pro A1708 - CPU extremely slow, locked @ 0.39ghz; fan full speed
            by gjlpereira
            Hi forum.
            I'm working on a macbook pro, model a1708, that is running extremely slow.
            Everything on it seams to work just fine, it just works extremely slow; painfully slow; especially running macos (windows and linux actually run OKish on it, slow, but usable).
            One other symptom of the problem with the machine is that the fan is always running at full speed.
            This machine has been worked on by someone else previously; they tried to repair it, but with no success. The motherboard does have sings of being worked on, but it all looks good/OK; like...
            09-06-2022, 07:45 PM
          • envym
            MacBook Pro 2018 with Activation Lock
            by envym
            Hi everyone!
            I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
            I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
            06-27-2025, 08:54 AM
