Razer RZ09-0423 missing IC
  • doivaythoiem
    • Jun 2024
    • 126
    • Việt Nam
    I lost this IC can someone give me the information pls
  • mon2
    • Dec 2019
    • 14758
    Not an IC but the same large bulk tantalum capacitor like the rest. Value will probably be the same. The part has a polarity so be sure to check the ‘+’ on the capacitor. This is important.
    • doivaythoiem
      • Jun 2024
      • 126
      • Việt Nam
      Originally posted by mon2
      Not an IC but the same large bulk tantalum capacitor like the rest. Value will probably be the same. The part has a polarity so be sure to check the ‘+' on the capacitor. This is important.
      red circle ​
        • 22182
        Originally posted by doivaythoiem
        red circle ​
        What is the motherboard model number
        • noname2024
          • Aug 2024
          • 295
          • CỎ MỸ XỊN
          người anh em. MOS DRIVER MP86941GQVT-C787-Z
          • doivaythoiem
            • Jun 2024
            • 126
            • Việt Nam
            IT IS LOCATED ON THE RIGHT SIDE NOT THE LEFT SIDE
            • doivaythoiem
              • Jun 2024
              • 126
              • Việt Nam
              • noname2024
                • Aug 2024
                • 295
                • CỎ MỸ XỊN
                trên Gen 11th nó là ic đó. hãy nhìn chân trên main và so sánh. ​ Click image for larger version
                • sect-sin
                  Razer Blade 15 (2020) missing components
                  by sect-sin
                  I have a Razer Blade Base (2020) notebook with 2 missing MOSFET's. The motherboard marking is DA550-MB MP V4.0. There are no schematics or boardviews available.
                  I have marked the missing components on the attached screenshot. If anybody has a similar or identical motherboard, please do tell me the part numbers.
                  Thank you very much in advance!
                  Cheers,
                  sect-sin...
                  09-26-2022, 03:18 PM
                • jpreza
                  Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                  by jpreza
                  I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                  Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                  It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                  Looking at the card, it appears to be missing the following:
                  1x 1.0uH inductor - orange square
                  2x...
                  11-01-2024, 10:54 PM
                • BYTEHAT248
                  Need help fixing ATI Radeon X800XL AGP 256 (Missing components)
                  by BYTEHAT248
                  Got this card out of a box of old electronics and am hoping there's a way to fix it, when i found it i put it in one of my desktops and it displays a kinda static like bars of color. so upon further inspection i noticed that it is missing a choke and a capacitor, and the other choke is cracked and there's a piece of it missing. im pretty good with smd soldering and i looked around quite a bit but cant seem to find what the part numbers of the missing components are. if anybody could help me out with this that would be great. the part number of the card is P/N 102A4900103 159312
                  11-14-2025, 04:48 PM
                • gurj1979
                  Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                  by gurj1979
                  Hey guys.
                  Need help with this one.
                  Fan not spinning due to missing PWN Fan signal.
                  Also 5 seconds from powering up it freezes, unless in BIOS.
                  But as soon as Windows starts to load, it will freeze.
                  CPU is COLD / Room temp when it freezes.
                  I've replaced the CPU, same problem.
                  Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                  Replaced fan - same problem.
                  Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                  Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                  08-19-2024, 05:22 PM
                • salopian
                  Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                  by salopian
                  Hello. I would need some advice please.
                  My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                  He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                  I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                  I have already replaced the logic board with another...
                  02-27-2021, 07:30 AM
