Help me to identify this IC!
  • Dcortest
    • Oct 2023
    • 33
    • España
    Hello all,
    I'm trying to fix an Asus Tuf FX507 2023 with multiple fails, but there is one component that I cannot found to replace. From the boardview I got this info: "LIN REG. SOT25 5P//INVENTEC/6019B2084201"
Name:	WhatsApp Image 2024-12-03 at 09.49.30.jpg
    Do you know what is this IC?
    Thanks for your help
  • noname2024
    • Aug 2024
    • 204
    • CỎ MỸ XỊN
    this info Click image for larger version
    • Dcortest
      • Oct 2023
      • 33
      • España
      I'm so stupid right now..... the name of the IC is labeled on pin 5 Netname "AP7343D15W57"
      Thanks noname2024
      • noname2024
        • Aug 2024
        • 204
        • CỎ MỸ XỊN
          • 20665
          Thanks noname2024
          The boardview shows a compatible part. The AP7343D-15W5-7 is marked 8KXXX (XXX = Year, Week , Internal code) .Datasheet - https://www.mouser.com.tr/datasheet/..._1-2543560.pdf
          Not sure what that IC marked 6T3dC is yet,my guess it`s a silergy part.
          • R_J
            • 9535
            AP7343D-33W5-7 Page# 15, it is a different voltage if it is a diodes inc. part number
            • Dcortest
              • Oct 2023
              • 33
              • España
              That's my next question.... change the defective IC with the boardview compatible part or change it with the Diodes inc. part number... 1.5V or 3.3V?
              • R_J
                • 9535
                Check what ic's it supplies and see what there vcc should be, otherwise I would go with the lower voltage and not risk damaging other components
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Very likely its a 3.3V LDO output linear reg
                  • thesame
                    DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                    by thesame
                    Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                    The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                    02-27-2024, 04:31 AM
                  • silver60618
                    Lenovo Legion 7 - Help Identify IC
                    by silver60618
                    Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                    I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                    Any help would be appreciated...
                    07-02-2025, 12:16 PM
                  • chth96
                    How can I identify varistor which have been blew up?
                    by chth96
                    I mistakely pluged 100v japanese retro game console to 220v outlet.
                    So It seems that glass fuse and varistor have been blew up.
                    I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                    Is there any way to identify varistor type in my sega saturn PSU?
                    Any reply would be appreciated.
                    EDIT:
                    It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                    11-26-2023, 08:52 AM
                  • freakorio
                    Need Help To Identify Component on Ymain LJ41-05120A
                    by freakorio
                    Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
                    05-21-2024, 02:32 AM
                  • baiceanu_stefan
                    nm-f251 Schematic, boardview or help identify componente
                    by baiceanu_stefan
                    Hello, I have a legion pro 5 16arx8 serial number pf4bf4aw mb code nm-f251 rev1.0 which was dissasembled by the client for cleaning. Now it does start but for 20 secs after that fans run at maximum and then shut down. Found PU8302 burned but cannot identify it the part. It is written eHFAA on it but didn't found any info, no boardview, nothing. Can anyone help identify the part so I can order it from somwhere? Ataching some pictures of the motherboard, serial number and part. Than\k you...
                    04-24-2024, 12:49 AM
