a1708 no backlight
  • Arshad alam4659
    • Aug 2020
    • 157
    • India
    a1708 no backlight
    a1708 820-00840-a no backlight no short no liquid damage i checked some voltage
    PPVOUT_S0_LCDBKLT=12.6v
    PP5V_S0_BKLT_A=5v
    PP5V_S0_BKLT_D=5v
    BKLT_SCL=4.5v
    BKLT_SDA=4.4v
    BKLT_EN_R=3.3v
    BKLT_PWM_KEYB=0v
    ISNS_LCDBKLT_N=13.04v
    ISNS_LCDBKLT_P=1303v
    BKLT_SD=9v
    BKLT_SENSE_OUT=0v
    LCDBKLT_FB=10.95v
    LCDBKLT_SW0.106v
    i changed u8400 and screen and small screen cable but same condition and also check resistor near u8400 all ok what i am missing someone help
  • mon2
    • 14657
    Are you sure you have video? Test with torch light. Keycaps led toggles?
    https://boards.rossmanngroup.com/thr...cklight.61666/
    • HTR-Informatique
      Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
      by HTR-Informatique
      YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
      I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
      On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
      I also changed the screen because the PC fell and the screen was broken.
      I changed the battery with a new and original battery.
      I also had corrosion/oxidation on the...
      02-09-2025, 06:51 AM
    • frannyjunk
      Hisense 40H4F no backlight but turns off after splash screen
      by frannyjunk
      So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
      TIA.
      09-24-2025, 10:59 AM
    • turmix
      AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
      by turmix
      Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
      The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
      At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
      During another reassembly, I made a mistake, and...
      01-29-2024, 03:48 AM
    • FallenOne008
      Asus G712L No Screen Backlight
      by FallenOne008
      Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
      The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
      03-31-2025, 08:27 PM
    • trepachka
      HP Probook 450 G8 Boardview+Schematics - screen backlight issue
      by trepachka
      I am just wondering if anyone has boardview+schematics for HP Probook 450 G8.
      Computer is missing screen backlight. The backlight fuse must be kaput. I know the fuse is located on the motherboard because we tried a different working screen and it, too is missing backlight.
      Perhaps, if the boardview+schematics are not available, someone can point out where the screen backlight fuse is located. Thanks.
      03-16-2024, 12:32 AM
