toshiba satelite l755-s5308 charging problem
  • abbas_govani
    • Jul 2013
    • 89
    • India
    hi i have toshiba satelite l755-s5308. working fine on ac adapter without battery. but does not start on battery and adapter both in and charging led is blinking orange.
    need help Please ............
  • cephei328
    sparky
    • Feb 2014
    • 49
    • NewZealand
    Re: toshiba satelite l755-s5308 charging problem
    Hi abbas, Check the Mosfets on battery side you should have 2. Cheers
    • delphi_firebird
      Toshiba Qosmio X755 Charging problem
      by delphi_firebird
      Hello Guys,
      I received Toshiba Qosmio X755 that has a charging problem and I'm stuck trying to figure out the problem.
      - When battery is unplugged i works without any problem.
      - When I plug in the battery after plugging in the charger, it works correctly and the battery is charging.
      - When I plug in the charger after inserting the battery, it stops working. ( voltage dropped and consumed 8A, reaching the maximum capacity of my bench power supply for 5 seconds, and stop working after )
      Can you help me diagnose the problem? I have attached...
      10-16-2023, 03:04 AM
    • huzo
      Strange problem charging battery Toshiba Z50-E
      by huzo
      First of all i haven't found the board number other then FLESSY2 G4227A A4227A etched under the DC in connector...
      The problem is laptop does not charge the battery...Laptop works on battery and work on charger, but doesn't charge the battery... when off, it pulls 0.13A ,when turned on it pulls around 0.500A and has spikes 0.6-0.8 A when booting, i found that ISL9238H is the charging regulator and i replaced it with ISL 9538H and it's all the same...i checked all the passive components and all seem to be ok...
      Anyone have an idea what to look for next? The battery...
      05-03-2024, 01:58 AM
    • ahmarzo
      Hp laptop charging problem
      by ahmarzo
      Have hp laptop motherboard part no opp 17 diner skl/kbl 15289-2 with charging problem.the laptop shows plug in charging but percentage doen not increases.the schematic or boardview is not available.
      Charging ic is bq737 with voltages on pin no
      1&2 -19v
      34&5 -0v
      6 -2.56 v
      7- 0v
      8&9 -3.15v
      10 -0v
      11 -0.18v
      12 & 13 -13v
      14&15 -0v
      16 -6v
      17;18&19 -13v
      20 - 19v
      Voltages on battery connector are
      1&2. -13v
      3&4 -3.14 v
      5&6 -0v
      8&9 are ground...
      03-20-2025, 05:13 AM
    • roman728
      Lenovo E15 / NM-C421 Charging Problem
      by roman728
      Hello guys,
      I have a problem with charging circuit in this laptop. Unit came with no power at all (USB-C meter was cycling turning off and on). I discovered that when I unplug battery laptop works on charger only. So after few measurements I found shorted 1st dual mosfet AONY36324. Unfortunately i was not able to order exact this one, so i ordered AONY36352 which i believe is the similar one. Now the problem is, when i connect battery and charger USB-C meter is not cycling anymore, it starts charging (reading 20V@2,7A) but after few seconds it is going down to 20V@0,20A and laptop...
      02-20-2024, 03:40 AM
    • serious_electron
      Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
      by serious_electron
      Hello Everyone!
      I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
      06-28-2025, 02:57 PM
