Dell Inspiron 15 AC adapter turns off as soon as connected (MB Short)
  • roxboy1984
    • Jan 2022
    • 177
    • South Africa
    Please can someone help me, im trying to find the shorted component as i have a donor board that i can swop components from.
    If i inject 2V/2A on DC in PU4201 gets really hot. ive changed out PU4201 from another board as well as a couple other Mosfets but PU4201 still gets crazy hot when i inject. Any ideas? im still a noob so am learning.
  • mon2
    • Dec 2019
    • 14631
    Can you link the schematic (but do not post it here)?
    Board works ok if on adapter voltage? Does PU4201 get hot if powered by the adapter only?
    • pc_okay
      • May 2022
      • 243
      • FRANCE
      Remove pu4201 and Check résistance between gate to source, drain to gate, drain to source and source to drain…. On both Of your mofset.
      Then Check résistance to ground on the board, on the location (on the Track) Of source, drain, gate (where the mofset should be)… (without the mofset)
      post your result .
      • roxboy1984
        • Jan 2022
        • 177
        • South Africa
        When you say works ok on adapter voltage, do you mean i should inject 19v using bench supply.
        link to schematic https://www.badcaps.net/filedata/fetch?id=1980830
        • roxboy1984
          • Jan 2022
          • 177
          • South Africa
          Then Check résistance to ground on the board, on the location Of source drain Of the mofset … (without the mofset)
          post your result .
          Thanks i will check this and post results as soon as i can.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Perhaps@mon2 didnt read the thread with attention. Dont inject 19V as the mb will be permanently damaged beyond repair. Proper way is injecting 1V/5A on shorted side. Btw, What is the resistance to GND on CLR pr4402? The mb seems like CEDAR 13269-1 to me.
            • retrorepair2
              Dell E5470 LA-C631p - Short removed now turns on but no post/display
              by retrorepair2
              Got a really frustrating issue here, got a Dell laptop as above which initially had a short on the +POWER_SRC rail, discovered a short cap in a bank of 3 near PU801. Removed and verified the short was gone, it was and the laptop powered on, tried to load windows but just kept rebooting. Sometimes didn't post. Battery was charging.
              Stripped it back down and replaced the cap (assumed looking at the LA-632p schematic it's a 10U cap, no boardview so who really knows). Now the board doesn't charge the battery and while it powers on with a brief spin of the fans, there's no display on the...
              09-25-2025, 07:12 AM
            • Victor Moreira Silva
              Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
              by Victor Moreira Silva
              I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
              Well, my decice specs are the following:
              Model: Acer Nitro 5 AN517-54-55T5
              CPU: Intel Core i5-11400H
              GPU: NVIDIA GeForce GTX 1650
              Motherboard: GH51G LA-L181P Rev:1c
              The symptom:
              When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
              05-26-2025, 10:49 AM
            • Kambi13
              Dell Inspiron 3542 Turns on works for 30 seconds to 1 minute then turns off
              by Kambi13
              Hi all need some help, I've got a Dell insprion 15 3542 that turns on works for about 30 seconds or sometimes a minute or two and then turns off and wont turn on again until I remove and replug the power connector
              Not heat related, everything is ok regarding to that.
              All voltages are present.
              Wondering if this as anything to do with one wire circuit, the charger is not original, but it was working fine
              Motherboard is Cedar 13269-1 F3XMC Rev A00...
              07-12-2024, 06:10 AM
              DELL Inspiron 3470 Inspiron 3000 i5-8400 Specification for Upgrade or Repair
              This specification for the DELL Inspiron 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3470 boardview and Inspiron 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
              09-12-2024, 03:44 PM
              DELL Inspiron 3268 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
              This specification for the DELL Inspiron 3268 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3268 boardview and Inspiron 3268 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
