dell inpiron n4050 is short
  • waqas
    • Jan 2014
    • 21
    • Pakistan
    Hi to all exparts
    I have DELL INSPIRON N4050
    Problem is as i plug charer in chargeieg jack the charger's LED went off....
    Laptop has still no power..
    I opend laptop and checked power jack is not short...
    There is some shortage on board...
    Plz guide me how to chek and fix the problem....
    I m new in this field...
  • alihomee
    • Dec 2012
    • 1591
    • malaysia
    Re: dell inpiron n4050 is short
    pic can help
    • dj_ricoh
      • 2073
      • uk
      and motherboard code , schematic,etc
      • waqas
        • Jan 2014
        • 21
        • Pakistan
        Its not broken dear....
        Plz guide me ...
        • dj_ricoh
          • 2073
          • uk
          let me understand you don`t how to open and you want to repair the motherboard?
          hmm that`s a "pickle"
          • waqas
            • Jan 2014
            • 21
            • Pakistan
            I can resolve basic problems ,
            I have changed many usb ports of laptop board...
            I never tried to resolve any major problem.g.g
            But now i want to go for that with help of u all...
            I hope u wil not dipspoint me...
            Plz share ur knowledge and experience ..
            • cephei328
              sparky
              • Feb 2014
              • 49
              • NewZealand
              Hi mate, when motherboard is short the following components go bad - Mosfets, Capacitors and sometime GPU (I dealt one such case with HP DV6 amd gpu). Well easiest way to test is set your multimeter to ohms range : First start testing all power fets which have 19 volts fed to their drains - simply put the probe between source to drain - then source to gate of mosfet (go online and read pin details of mosfets for better understanding - you can see some marking on the m/b which tells fet's pin 1 which is source and pin 4 is gate)
              Test only power Fet's and get reading (should not read .1 ohms +_) if yes then turn your attention towards that part and capacitors surrounding it.
              Good Luck
              • loser18
                • Nov 2013
                • 274
                How do you know it's shorted???
                I would start with mobo part number, so can look for the right schematics...
                • atsio
                  • Oct 2013
                  • 819
                  • Greece
                  • loser18
                    • Nov 2013
                    • 274
                    Doesn't have to be short...May be some regulator faulty...no?
                    • dj_ricoh
                      • 2073
                      • uk
                      its like every time i see a dell that shutdown the adapter i say No! ty . but here its like 90% everybody will say its a bad cap on that motherboard.
                      i will rly like to see a how to find that stupid cap because i have at work 2 dells xps and one could be mine if i know to to find that stupid cap.
                      yes i know voltage injection but still where the hek should i inject.
                      • Geeker007
                        9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                        by Geeker007
                        Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                        I am new to electronics repair, so my queries could be naive but I am ready to learn.
                        So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                        01-28-2025, 03:31 PM
                      • retrorepair2
                        Dell E5470 LA-C631p - Short removed now turns on but no post/display
                        by retrorepair2
                        Got a really frustrating issue here, got a Dell laptop as above which initially had a short on the +POWER_SRC rail, discovered a short cap in a bank of 3 near PU801. Removed and verified the short was gone, it was and the laptop powered on, tried to load windows but just kept rebooting. Sometimes didn't post. Battery was charging.
                        Stripped it back down and replaced the cap (assumed looking at the LA-632p schematic it's a 10U cap, no boardview so who really knows). Now the board doesn't charge the battery and while it powers on with a brief spin of the fans, there's no display on the...
                        09-25-2025, 07:12 AM
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • aaronkatrini
                        DELL Nvidia GTX 750Ti Mosfet goes short after a few minutes
                        by aaronkatrini
                        I have recently picked up this Dell OEM Nvidia GTX 750Ti 2GB Video card. Its an old card I know but still wanted to get it working if possible. The problem is the following:
                        - Put the card in my testing motherboard and start running Heaven benchmark
                        - Benchmarks seems to run smoothly up until half way then the motherboard completely shuts off immediately
                        - Try to start it again and I get a slight move from the PSU fan - a clear short
                        - A little troubleshooting later I find one shorted Mosfet - Replace them both - short is gone
                        - Put the...
                        05-18-2025, 04:18 PM
                      • playit
                        laptop 19v short circuit dell vostro 1400 motherboard ,need help in repair .
                        by playit
                        the comon problem they say , the charger will shut off power once plugged to laptop , i dont have battery, its long gone ago , i use it for backup with adapter and vga port to external monitor(yes no screen lcd) in case my desktop needs fix . one thing for sure i could say the clr resistor - r010 beeps ,short at both sides , the checked all the coils , the 3 coils together gives all of them beeps short along with their respective capacitors . i dont have voltage ampere injection dc machine as in videos i have seen they see where its getting hot and they remove the short and replace components...
                        02-25-2025, 08:15 AM
