dell inpiron n4050 is short
  • waqas
    • Jan 2014
    • 21
    • Pakistan
    Hi to all exparts
    I have DELL INSPIRON N4050
    Problem is as i plug charer in chargeieg jack the charger's LED went off....
    Laptop has still no power..
    I opend laptop and checked power jack is not short...
    There is some shortage on board...
    Plz guide me how to chek and fix the problem....
    I m new in this field...
  • alihomee
    • Dec 2012
    • 1574
    • malaysia
    Re: dell inpiron n4050 is short
    pic can help
    • dj_ricoh
      • 2073
      and motherboard code , schematic,etc
      • waqas
        • Jan 2014
        • 21
        • Pakistan
        Its not broken dear....
        Plz guide me ...
        • dj_ricoh
          • 2073
          let me understand you don`t how to open and you want to repair the motherboard?
          hmm that`s a "pickle"
          • waqas
            • Jan 2014
            • 21
            • Pakistan
            I can resolve basic problems ,
            I have changed many usb ports of laptop board...
            I never tried to resolve any major problem.g.g
            But now i want to go for that with help of u all...
            I hope u wil not dipspoint me...
            Plz share ur knowledge and experience ..
            • cephei328
              sparky
              • Feb 2014
              • 49
              • NewZealand
              Hi mate, when motherboard is short the following components go bad - Mosfets, Capacitors and sometime GPU (I dealt one such case with HP DV6 amd gpu). Well easiest way to test is set your multimeter to ohms range : First start testing all power fets which have 19 volts fed to their drains - simply put the probe between source to drain - then source to gate of mosfet (go online and read pin details of mosfets for better understanding - you can see some marking on the m/b which tells fet's pin 1 which is source and pin 4 is gate)
              Test only power Fet's and get reading (should not read .1 ohms +_) if yes then turn your attention towards that part and capacitors surrounding it.
              Good Luck
              • loser18
                • Nov 2013
                • 274
                How do you know it's shorted???
                I would start with mobo part number, so can look for the right schematics...
                • atsio
                  • Oct 2013
                  • 819
                  • Greece
                  • loser18
                    • Nov 2013
                    • 274
                    Doesn't have to be short...May be some regulator faulty...no?
                    • dj_ricoh
                      • 2073
                      its like every time i see a dell that shutdown the adapter i say No! ty . but here its like 90% everybody will say its a bad cap on that motherboard.
                      i will rly like to see a how to find that stupid cap because i have at work 2 dells xps and one could be mine if i know to to find that stupid cap.
                      yes i know voltage injection but still where the hek should i inject.
