A1706 - 5v due short 3.3v LDO
  • iMuhtaseb
    • Jan 2017
    • 122
    • Palesine
    Board was OK but after keyboard replacement; we found short on 3.3 LDO on UB300 (CD3215).. I removed it and of course I tore off some pads because its undefiled.. pads are repaired successfully.. diode and continuity tests done Pads were USB_UPC_TA_F_P and TP_UPC_TA_SWD_DATA and UPC_TA_SPI_MISO..
    After replacing UB300 the watts consumption lowered since short is gone but still is stuck @ 5v (0.06amps)
    I noticed few balls around UB400 so I assumed it needed reball; reballed and replaced it; still 5v.. on both sides
    While on the other wing U3200 and U3100 are doing the switch.. turning on and off on ammeter indicating they're trying to switch
    UB300 and UB400 are not switching or attempting to
    UB300 LDOs are all four present
    UB400 LDOs present except for BMC
  • mon2
    • Dec 2019
    • 14012
    LDO for the BMC on the active port must be present.
    • iMuhtaseb
      • Jan 2017
      • 122
      • Palesine
      I replaced UB400 again.. still on 5v and no BMC
      • mon2
        • Dec 2019
        • 14012
        Remove all power. Meter in resistance mode. What is the resistance to ground on this missing BMC LDO rail? Then switch to diode mode. Red meter probe to ground, yes ground. Black meter probe onto the same missing BMC LDO rail.
        What is the measurement in diode mode? Both tests will assist us to determine if there is a fault on this missing LDO rail. Again, this rail is only active if this PD controller and USB-C port is being used to power the board.
        • iMuhtaseb
          • Jan 2017
          • 122
          • Palesine
          UB400 BMC LDO:
          Resistance: 200 kOhms and rising
          Diode: 0.536
          • mon2
            • Dec 2019
            • 14012
            So no shorts here. Can you inspect the USB C connector pads to see if they are ok? If available to you, consider to swap out the paddle board that houses these USB C connectors. The pads do wear out. We have seen a few with cat urine, etc. onboard and that also will affect the operation of the adapter voltage negotiations.
            This article is applicable to study for your case:
            https://logi.wiki/index.php/CD3215_Bootup_Sequence
            • iMuhtaseb
              • Jan 2017
              • 122
              • Palesine
              Found one problem with UB300 with line UPC_TA_R_OSC it was reading 2.4 in diode mode.. I replaced that UB300
              Found another problem with UB400 with lines UPC_TB_DBG3 and UPC_TB_DBG4 they were reading OL.. replaced that UB400 and issue was resolved, 20v back.
              • mon2
                • Dec 2019
                • 14012
                Bravo! Well done. What is the current draw? Do you have booting now?
                • iMuhtaseb
                  • Jan 2017
                  • 122
                  • Palesine
                  well, yes.. it was booting just fine.. and I gave it back to the customer after testing and stressing the computer.. few weeks we come to today and it does not show an image..
                  It switches to 20v, consumes a fair amount of amperage (goes up to 700 mA then drops to 400 mA) and CPU gets hot.. but no image on screen and I measured CPU voltage its there but GPU voltage is not..
                  I got it to work one time but it got stuck to the Apple logo not showing anything else...
                  Another than my previous work on the CD3215s (which are OK since it switches to 20v and powers on) the board is spotless.. what could've happened?!
                  edit: its the AUX short situation.. I checked the diode readings for both lines they're OK..
                  • mon2
                    • Dec 2019
                    • 14012
                    Test if you see an image using an external screen. A1706 is linked to flexgate so you may now be fighting a different demon.
                    https://www.youtube.com/watch?v=5nBiN8Uujlw
                    • iMuhtaseb
                      • Jan 2017
                      • 122
                      • Palesine
                      Yeah I've tested the flexgate scenario; cable is good, I've tested it another screen just to be sure.. no image And on external screen (even bare board) no image, this device usually shows an image even bare board..
                      • mon2
                        • Dec 2019
                        • 14012
                        Issue may be with the display mux @ U3610. Inspect for damage.
                        Lid sensor status (trackpad) working ok? Test with the lid open / closed.
                        This is SMC_LID.
                        • iMuhtaseb
                          • Jan 2017
                          • 122
                          • Palesine
                          I have taken a look at U3610, yes, nothing seems off.. I'm thinking of reflowing tbh.
                          SMC_LID is a great hint! But sadly it is present at 3.4v Hall sensors are on 3.4v
                          • iMuhtaseb
                            • Jan 2017
                            • 122
                            • Palesine
                            I checked the coils around U4200; ok
                            I checked the LVDS connector in diode; readings OK compared to OBD and another board
                            Seen a vid on YouTube where a guy replaces the audio codec jack and it fixes the issue; I didn't find any abnormalities, shorts or high/low diode readings..
                            • iMuhtaseb
                              • Jan 2017
                              • 122
                              • Palesine
                              I found a small crack on U4200; replaced it same thing
                              I replaced both hall sensors in hopes; sadly didn't fix
                              I cannot find any enable signal for the screen..
                              I don't know what's wrong with this haunted computer; could it be firmware?
                              • iMuhtaseb
                                • Jan 2017
                                • 122
                                • Palesine
                                I've put another known-good board of mine to the customers housing; my board showed an image for brief moment and it stopped.. now it is exhibiting the same issue.. I lost a good board 😒
                                What I connected to board are Touch Bar Display, Touch Bar Touch, Trackpad, Keyboard, Audio Jack, Touch ID, Type-C connectors and display...
                                Diode mode are ok in LVDS, TB disp, TB touch, trackpad, keyboard, audio jack, Touch ID.. I am yet to test type-c connectors..
                                • mon2
                                  • Dec 2019
                                  • 14012
                                  There is a lot going on in this thread. What are the symptoms at this stage?
                                  Is the USB C port @ 20v or stuck @ 5v? Current draw from the adapter?
                                  Voltage of PPBUS_G3H to ground? Is it a stable voltage or power cycling?
                                  If the PPBUS_G3H is not within proper range, remove all power -> meter in resistance mode -> check the resistance to ground on PPBUS_G3H.
                                  Also measure the voltage to ground of the SMBUS SCL / SDA lines on the battery connector since they are shared across the ISL and other regions on the board.
                                  • iMuhtaseb
                                    • Jan 2017
                                    • 122
                                    • Palesine
                                    Sorry about the post, it's been cluttered for my numerous and attempts and recording each step here..
                                    USB-C ports switch to 20v and current draw goes to up 0.8 mA then drops to 0.4 mA and stays there..
                                    Symptoms: CPU heats up.. S0 is present but no enable signals coming to power on the LCD..
                                    PPBUS is stable @ 13v Diode mode 0.454
                                    Resistance mode 55 kOhms
                                    PM_SLP_S4 and PM_SLP_S3 are present
                                    SMBUS SCL SDA lines from 0 to 5 tested with diode mode measurement and compared to another board; they're all similar to my good board.
                                    • mon2
                                      • Dec 2019
                                      • 14012
                                      "check CPU core voltage after 10-15 seconds"
                                      L7210/20...​
                                      • iMuhtaseb
                                        • Jan 2017
                                        • 122
                                        • Palesine
                                        hmmm..
                                        L7210​ turns on after PD switches to 20v @ 1v for exactly 10 seconds then drops to 0.92v for a second then drops to 0.65v and stays there..
                                        L7220 same thing; 1v -> 0.92v -> 0.65v
                                        That's a remarkable observation mon2!
                                        Bu what does it mean? 😁
                                        • rilley
                                          MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
                                          by rilley
                                          I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
                                          I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
                                          My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
                                          And the resistor L4004 is literally burned.
                                          From what I see from the schematics, it does not affect any other rails, only the connection to the display...
                                          07-10-2024, 01:57 AM
                                        • DynaxSC
                                          Extreme High Current & Low Voltage Short Killer ??
                                          by DynaxSC
                                          Hi Folks
                                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                          After taking off the socket, the shorts dissappear again.
                                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                          10-15-2024, 10:13 AM
                                        • madjid911
                                          A1706 short PP3V3_S5
                                          by madjid911
                                          Hi friends,
                                          I have a macbook pro A1706 820-00923-A that won't start no signs of life, no liquid, checking the voltages I found PP3V3_S5 was shorted, I removed all the processor coils, but when I 'injects a voltage it is the processor which reacts, can you confirm to me that this is definitely coming from there please?
                                          I have 20V on the usb-c connector, and 13v stable on​ ppbus_g3h.
                                          I saw that a track had burned out on PPVIN_2V7NAND_LB after resistor R9350
                                          I injected voltage on L7660 pin 1 in short but only the processor reacts
                                          Thanks for your...
                                          05-18-2024, 12:33 PM
                                        • Stephen
                                          MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                                          by Stephen
                                          I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                                          02-06-2025, 12:03 PM
                                        • Victor Moreira Silva
                                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                          by Victor Moreira Silva
                                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                          Well, my decice specs are the following:
                                          Model: Acer Nitro 5 AN517-54-55T5
                                          CPU: Intel Core i5-11400H
                                          GPU: NVIDIA GeForce GTX 1650
                                          Motherboard: GH51G LA-L181P Rev:1c
                                          The symptom:
                                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                          05-26-2025, 10:49 AM
