dell n5110 no charger detect
  • abbas_govani
    • Jul 2013
    • 89
    • India
    Hi i have a dell n5110 laptop.
    it was dead as it was water damage.
    i cleaned all the corrosion and replace one of the p channel mosfet.
    its now working but charger is not detecting
    I had replaced the charger but same problem.
    also re soldered all the charger point.
    i had search the net but there is no schematic for power board
    (dq15dn15 crt board)
  • loser18
    • Nov 2013
    • 274
    Re: dell n5110 no charger detect
    Try this 1...
    What do you mean charger is not detecting???
    Does it work on battery only???
    Did you check charging circuit???
    • abbas_govani
      • Jul 2013
      • 89
      • India
      hi there i had checked center pin there is 2.8v when i connect the charger.
      • abbas_govani
        • Jul 2013
        • 89
        • India
        laptop works on charger and battery too but not detecting charger
        thanks
        • loser18
          • Nov 2013
          • 274
          I don't understand you...
          How could it start up when charger is not detected?
          You mean it works on battery only...
          If you're reading 2.8V on DC jack, you have a short on it, or short somewhere on charging circuit...
          • loser18
            • Nov 2013
            • 274
            Sorry mate...
            I'm a dumbass...
            Didn't read it properly...
            Did you try to measure DC jack on power board disconnected from mobo?
            • abbas_govani
              • Jul 2013
              • 89
              • India
              hi sir
              it is working complete on battery and charger too
              but not charging the battery
              and bios shows no charger connected
              • loser18
                • Nov 2013
                • 274
                Still need to clarify...
                -It works on charger (without battery connected-only charger)
                -It works on battery (without charger connected-only battery)
                -& it also works when plugged in battery & charger, but it's not charging the battery
                • dj_ricoh
                  • 2073
                  i have to ask because i have a universal charger that i use for all notebooks adn that one does not charge the dell battery`s only the original one with a good power like over 90W; mine its 135W
                  • abbas_govani
                    • Jul 2013
                    • 89
                    • India
                    i had checked it.
                    there is 19.5v
                    and center pin sows nothing.
                    while connected to mobo it shows 2.8v
                    • abbas_govani
                      • Jul 2013
                      • 89
                      • India
                      it works on all three but not charging
                      • abbas_govani
                        • Jul 2013
                        • 89
                        • India
                        i use dell orignal adapter and checked on other dell laptop charger is fine
                        • abbas_govani
                          • Jul 2013
                          • 89
                          • India
                          yes sir
                          • loser18
                            • Nov 2013
                            • 274
                            Could you measure voltages on all pins @ PU4002 & PQ4001???
                            • dj_ricoh
                              • 2073
                              the mid pin has to give voltage
                              • abbas_govani
                                • Jul 2013
                                • 89
                                • India
                                pu4002 gate 1.8, source 19 and drain 19
                                • abbas_govani
                                  • Jul 2013
                                  • 89
                                  • India
                                  yes it gives 2.8v
                                  • loser18
                                    • Nov 2013
                                    • 274
                                    Yes, but he says it works on charger, without battery plugged in, so reckon it's getting 19V...
                                    Confusing
                                    • abbas_govani
                                      • Jul 2013
                                      • 89
                                      • India
                                      pq4001 pin 1 ground, pin 2 3.3v, pin 3 19v, pin 4and 5 no current and pin 6 ground
                                      • abbas_govani
                                        • Jul 2013
                                        • 89
                                        • India
                                        hi sir
                                        there is no Confusing
                                        laptop is not charging the battery that is the problem
                                        • toniu-massa
                                          Dell 15-5570, CAL50/DAL50 LA-F115p - Does not detect original charger
                                          by toniu-massa
                                          Hello, everyone!!! Happy New Year to all!!!
                                          When I turn on the laptop, the warning appears: You have attached an undersized 0W adapter and blah, blah, blah... The bios says that the adapter is not connected and the battery status is excellent.
                                          This laptop has all the voltages at the input, and the charger IC is also normal. There is 3.3V at the PS_ID and I have already tested it with another adapter, also original. The adapter detector also seems to work normally. I am suspecting the SIO. What do you think?
                                          On my portable oscilloscope there is a PS_ID signal....
                                          01-02-2025, 02:02 PM
                                        • BTubbs200
                                          Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                          by BTubbs200
                                          Dell Latitude 5420 P137G
                                          Board: LA-K491P REV A01
                                          I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                          Board seems to have no shorts, all power rails are fine and show high resistance.
                                          When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                          01-24-2025, 08:15 PM
                                        • Johndill
                                          Dell Inspiron 7567 LA-D993P odd charger issue
                                          by Johndill
                                          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                          Here are the tested scenarios:
                                          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                          2. With the laptop off, plug in charger (LED says on) & the front charging...
                                          11-16-2022, 10:55 PM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • PowerAmpFreak
                                          Dell Latitude 7280 does not recognize charger
                                          by PowerAmpFreak
                                          I have a Dell Latitude 7280 which complains during boot-up that the charger wattage cannot be determined. Tested with two different chargers.
                                          Any common faults that could be fixed?
                                          I replaced the DC jack, the original DELL LATITUDE 7280 DC30100Z300 0DP4VC.
                                          How does the communication between the charger and the PC work?...
                                          07-28-2025, 07:18 AM
