dell n5110 no charger detect
  • sanehdeep2012
    • Oct 2013
    • 139
    • india
    #41
    Re: dell n5110 no charger detect
    H ABBAS GOVANI YOU ARE RIGHT AT YOUR POINT
    your charge is also ok and battery is also ok
    your problem in charge detection circuit,
    in dell laptop and charger there is third pin in adapter, which should work and this send a data to laptop through adaptor third pin that this is a genuine and matching rating adapter. if this signal not goes to laptop the adapter show in laptop but not charging, if you check the battery status in laptop this will show "adapter connected, but not charging"
    it is belong to the center pin of your charger , trace the circuit of adapter power socket center pin circuit,
    pl check PQ4004 AND PQ4003 AT ICREF PIN AT PU4001 (BQ24745)
    i was facing this problem two times same as water spell NR adapter socket,
    again you are right adapter connected but not charging this is common problem with dell laptops, these laptop not working with local or other adapter these working with there own adaptor and with same power rating like 65w and 95w
    • abbas_govani
      • Jul 2013
      • 89
      • India
      #42
      this board does not have bq24745.
      it has bq24707a
      • proman28
        • May 2014
        • 9
        • uk
        #43
        hi i have fixed quite few of these models keyboard controller faulty quite common if spillage ocurs the adp detect pin goes short and symptom is not charger detection change the controller
        • abbas_govani
          • Jul 2013
          • 89
          • India
          #44
          liquid spill was on crt card and daughter card only. center pin gives 2.8v. and laptop is in working condition too.
          • loser18
            • Nov 2013
            • 274
            The question is, which one of those 2 different voltages is right?
            Because 1st indicates that charger is not detected & second that it's on protect mode...
            • abbas_govani
              • Jul 2013
              • 89
              • India
              #46
              it is crt card problem
              there should be 3.2v on center pin.
              i replaced the crt card and it works fine.
              • dspok
                • Jan 2014
                • 553
                • Nepal
                #47
                I have same problem with N4110 center pin is pushing 3.2v to SIO but still not charging. I'll change SIO & see what happens.
                • cyberhack
                  • Feb 2013
                  • 466
                  • Uk
                  #48
                  remove battery when charger in and reinstall/remove/reinstall a few times the battery look at the charger indicator in windows ,could be just a duff battery.
                  sorry wrong post
                  • afrosh
                    • Oct 2012
                    • 6
                    • india
                    #49
                    search for ps_id......in any dell circuit.....there will be a circuit connected to the center pin of the female adpater connector maximun fault found was the ressistance value was not appropriate or it didnt ultimately connect to the ps_id in of i/o......good luck
                    • afrosh
                      • Oct 2012
                      • 6
                      • india
                      #50
                      it has nothing to do with charging ic or mosfet
                      • Zeyn
                        • Aug 2015
                        • South Africa
                        #51
                        Hi badcaps dudes. I've got a real headache with the dell DC Power Jack For Dell Inspiron N5110 Board and I cant order it in the country I live in so I gotta fix it but Im kind of a noob when it comes to electrical engineering
                        • jitendrakataria
                          • Dec 2015
                          • india
                          #52
                          sir what i can do this is my same problem
                          and i follow up your instruction then after my laptop is going for deth no pawer and no charger indicater led is on condition
                          • mohammed aram
                            • Apr 2015
                            • 73
                            • egypt
                            #53
                            To late.
                            any way.
                            the id pin (Central pin) in dell charger is different than hp & lenovo.
                            Not just enough voltage on this pin to go on charging process correctly.it's a digital bus called one wire circuit.
                            the only way to sea this data through Dso and read it through logic analyzer.
                            this data transfer from kbc and eeprom inside the charger and vice versa.
                            This is short.
                            This only The first step In the charging process
                            • toniu-massa
                              Dell 15-5570, CAL50/DAL50 LA-F115p - Does not detect original charger
                              by toniu-massa
                              Hello, everyone!!! Happy New Year to all!!!
                              When I turn on the laptop, the warning appears: You have attached an undersized 0W adapter and blah, blah, blah... The bios says that the adapter is not connected and the battery status is excellent.
                              This laptop has all the voltages at the input, and the charger IC is also normal. There is 3.3V at the PS_ID and I have already tested it with another adapter, also original. The adapter detector also seems to work normally. I am suspecting the SIO. What do you think?
                              On my portable oscilloscope there is a PS_ID signal....
                              01-02-2025, 02:02 PM
                            • BTubbs200
                              Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                              by BTubbs200
                              Dell Latitude 5420 P137G
                              Board: LA-K491P REV A01
                              I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                              Board seems to have no shorts, all power rails are fine and show high resistance.
                              When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                              01-24-2025, 08:15 PM
                            • Johndill
                              Dell Inspiron 7567 LA-D993P odd charger issue
                              by Johndill
                              Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                              There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                              I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                              Here are the tested scenarios:
                              1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                              2. With the laptop off, plug in charger (LED says on) & the front charging...
                              11-16-2022, 10:55 PM
                            • Bowline
                              by Bowline
                              06-11-2025, 10:13 AM
                            • exerion5000
                              DELL Alienware 17 R3 (LA-C912P) only work with 120w charger in mode low CPU clock
                              by exerion5000
                              Hello, I received this laptop with the following condition: When I turn it on, it shows the ALIENWARE light and the Alien button lights up, then it does not show an image and it restarts constantly, as the customer had already informed me that the battery was dead, I connected an original charger that I had it for testing, the machine turned on normally and I was able to enter Windows without problems, after a while of testing I noticed that it is very slow (like a Cyrix 425...), and after performing a CPU test the frequency is
                              below normal, as if it were operating in an extreme energy...
                              10-15-2023, 02:12 PM
