macbook a1706 820-00923 NO SSD
  • PITERPENY
    • Jul 2023
    • 455
    • Ukraine
    need help! macbook turns on but does not see ssd (folder with question mark). in disk utility also not through system recovery! 2.7v is missing!
    PICCOLO_IUVD=1.83v!
    PP3V3_S5_SSD=3.3v!
    replacing U9300 did not give result!​
  • mon2
    • 14021
    What is the resistance to ground of the missing 2v7 rail (without power to the board of course)?
    • PITERPENY
      • Jul 2023
      • 455
      • Ukraine
      found that PP5V_S4 is present but the lines have high resistance of about 21 ohms (instead of 8 kiloohms)! but there is no short! having dropped almost everything that is on this line (this is not a little)) I found the culprit of high resistance U3500! I replaced it and I got all the voltages on the SSD side:
      PP0V9_SSD_REG=0.9v
      PP1V8_SSD_COLD=1.8v
      PP1V2_SSD_HOT=1.2v
      PP3V3_2V7_NAND_VCC=2.7v
      P2V7NAND_PGOOD=2.7v
      but the damn SSD still does not see the Mac (​
      • mon2
        • 14021
        Maybe SSD is nuked?
        • PITERPENY
          • Jul 2023
          • 455
          • Ukraine
          most likely! perhaps the ssd file is damaged since all U8600 PCIE_SSD lines are active and access the ssd but... another repair failed!
          • mon2
            • 14021
            Be sure it is not one of these issues:
            https://m.youtube.com/watch?v=WbuRSU...ndex=4&pp=iAQB
            • PITERPENY
              • Jul 2023
              • 455
              • Ukraine
              he lost the line PP1V8_SSD_COLD=1.8v! I have it!
              • mon2
                • 14021
                https://www.youtube.com/watch?v=VuY4gn1CkKM
                • PITERPENY
                  • Jul 2023
                  • 455
                  • Ukraine
                  In the video he just installed 4 new SSD chips! Don't they need to be programmed? Or is this only the case with the T2?
                  • mon2
                    • 14021
                    Never done this but yes, my understanding is only T2 needs the extra care. Dosdude1 has a similar video where he installed a fresh ssd using a board from iBoff. Check their website for details. Keep us updated on this case.
                    https://iboffrcc.com/pages/-guide-so...016-2017-a1706
                    • Danielreinaa
                      HELP need password bios Macbook A1706
                      by Danielreinaa
                      Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                      Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                      Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                      gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                      Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                      09-07-2024, 03:47 PM
                    • capon5153
                      Macbook A1706 works perfectly but no data on USB C
                      by capon5153
                      hello,
                      so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
                      i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
                      06-22-2025, 09:42 AM
                    • B2L_Repairs
                      Macbook A1706 touchpad and keyboard not working. Please help
                      by B2L_Repairs
                      Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
                      10-09-2023, 04:56 AM
                    • obelix24
                      A1706 - Macbook pro - one USB-C port only 20V 0A
                      by obelix24
                      I just got in my hands one Macbook pro A1706. It was originally not turning on (only 5V 0,2a on all ports (and 3 ports were restarting ampmeter when connected)
                      I've replaced one CD3215C00 IC and now macbook is fully working (20V and charging fine)
                      There is only 1 issue that one USB-C port is taking 20V but 0A (after replacing CD3215 it was fully working and i was charging macbook on this port) but then it just turns off (ampmeter) and started with only 20V 0A.
                      There were some broken pads under CD3215 but i've recreated them.
                      What should be...
                      05-22-2024, 08:04 AM
                    • envym
                      by envym
                      Hi everyone!
                      06-27-2025, 08:54 AM
