Alienware M17 R3 M/B LA-J521P charging issues
  • ub6ib969
    • Jul 2010
    • 198
    yes pq12 is soldered on board. Measured using 2K ohm
    source to drain = .0L
    source to gate = .0L
    gate to drain = .0L
    • mon2
      • Dec 2019
      • 14319
      Keep increasing the resistance scale till you have a measurement that is no 'OL' = over limit.
      We need to know the resistance of the mosfets.
      • ub6ib969
        • Jul 2010
        • 198
        moving counter clock each measurement.
        2M ohm selected
        source to gate = 1.001
        gate to drain = .0L
        I got the same measurement at 20M (1.00)
        • ub6ib969
          • Jul 2010
          • 198
          I was getting 3.2v at G4_DCIN now i get 0v and D4_DCIN 16.95V at PQ8. Then the area of pus801 gets very hot.
          • mon2
            • Dec 2019
            • 14319
            Remove all power. Meter in resistance mode (not diode mode). Measure the resistance to ground of PUS801 (LDO output). What is the resistance in ohms? If the meter reports 'OL' = over limit, then switch to a higher meter scale till you have a measurement. We are checking if there is a shorted part on this power rail which will cause PUS801 to be a higher temp than normal.
            • ub6ib969
              • Jul 2010
              • 198
              #26
              2M OHM Measurement.
              PUS801 PIN 1 +20_LDO_INPUT = 0.232
              • ub6ib969
                • Jul 2010
                • 198
                #27
                do you think this could be pus05 ?
                removed PQ12 and in diode mode measured source to gate = 0.549
                resistance measurement at 2M ohm = 1.001
                • ub6ib969
                  • Jul 2010
                  • 198
                  #28
                  found that psc812 is missing near pus801 however schematics displays @RF@ so was this removed? any help would be great thanks
                  PCS812 is reserved for rf request. No component.
                  • rogfanther
                    • Jul 2006
                    • 458
                    • Brazil
                    #29
                    Componentes marked with @ on the schematic are "Do not install". These came from the factory already not fitted in the board.
                    • ub6ib969
                      • Jul 2010
                      • 198
                      #30
                      thanks
                      figured that once I looked up other components with the @RF@ label.
                      • siddiq
                        • Dec 2011
                        • 121
                        • Ghana
                        #31
                        How did this repair go... were you successful?
                        • armands0212@gmail.com
                          Alienware 13 power/freeze issues
                          by armands0212@gmail.com
                          hi guys.i have problem with alienware 13 r1.Basically its running ok as long as it is on power supply and i dont put it on sleep(if put it on sleep it wont wake up just freeze and need to do hard shut down),if running only on battery than it freeze straight away on account login screen.
                          But if i disable nvidia gpu and running only on intel hd graphics than no problems at all.
                          Look like laptop previously have been overclocked as base speed is 2.4ghz but should be only 1.7ghz and if i try disable overclocking in bios nothing changes.
                          i tried to adjust power managment...
                          12-20-2022, 09:23 AM
                        • z32KRAzY
                          Alienware 15 R3 Motherboard Issues Help Plz!
                          by z32KRAzY
                          Hi, I have an Alienware 15 R3 that I just bought a new motherboard for from ebay.. I have been trying to figure out this issue for 2 weeks already and I've decided I need help from the pros.
                          Laptop specifics:
                          Model : Alienware 15 R3
                          CPU : i7 6820HK
                          GPU : Nvidia GTX 1080 Max Q
                          RAM : 16GB PC4-19200 (8GB x 2)
                          STOR : 256GB M.2 SSD + 1TB HDD
                          Motherboard : Compal LA-D753P Rev 1.0
                          Problem : The laptop runs fine with most things, even GPU/CPU stress tests seem to run without problems for extended periods of time. BUT...
                          08-07-2022, 06:08 AM
                          Alienware 13 R3 Notebook Specification for Upgrade or Repair
                          This specification for the Alienware 13 R3 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13 R3 boardview and 13 R3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Alienware 13 R3 Notebook...
                          09-06-2024, 06:42 AM
                          09-06-2024, 06:34 AM
