Pls help me !! Trackpad macbook air m1
  • conghuyms
    • Apr 2022
    • 50
    • Vietnam
    My MacBook Air M1 2020 has a trackpad issue. I checked and found that one capacitor and one resistor are missing on the trackpad. I don’t know the value of the missing resistor. Could someone please help me? I’ve attached an image below showing the location of the missing components. Thank you all
  • conghuyms
    • Apr 2022
    • 50
    • Vietnam
    Pls
    • conghuyms
      • Apr 2022
      • 50
      • Vietnam
      • mon2
        • Dec 2019
        • 14662
        The middle 2 vertical pads look like they have a direct PCB trace between them so this part is not necessary - can you confirm?
        • conghuyms
          • Apr 2022
          • 50
          • Vietnam
          Thank you for your response.
          The orange line is the bridge for the capacitor.
          But the green line is the bridge for the resistor. I need to know the resistance value of that resistor; can you help me?​
          • fajfelek
            Macbook Pro M1 a2338 after liquid damage - Need help with identify missing part on trackpad logic board
            by fajfelek
            Hello, First of all thanks you for reading this topic.
            I need your help with identify missing parts on trackpad logic board (661-18430).
            The liquid got into the orange area, but I found that the green area had some parts missing or burnt.
            Please help me with identity parts from blue and red area .
            06-15-2024, 01:41 PM
          • No Lan
            [Macbook pro A1708] [Boot loop] [Trackpad ?]
            by No Lan
            Hey everyone,
            Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
            Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
            Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
            05-24-2025, 03:09 PM
          • Skrndelj
            Apple Macbook Air M1 A2337 Trackpad problem
            by Skrndelj
            Hello all,
            I am repairing a Macbook A2337 and i have a problem
            The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
            When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
            I inspected the whole board and everything seems fine.
            Can anyone help me as i didn't fiddle with trackpad...
            06-11-2024, 04:26 AM
          • rynr
            MacBook Air M2 A2681 no Trackpad
            by rynr
            I have been following the posts in the forum for some time now and have learned a lot. I would first like to thank you for this and hope that it will continue for a long time.
            I received the MacBook in DFU. The recovery always failed with error 1. After some search, I was able to find a defective inductor (LT202).
            After replacing the component, I was able to successfully complete the DFU restore. Unfortunately, the trackpad and keyboard where still without function.
            So i measured all voltages and diodereadings on the JT400 connector. ...
            11-04-2024, 09:56 AM
          • Woodsworth
            MacBook Pro A2289 no signs of life except clicking trackpad and charging
            by Woodsworth
            I hope this is the correct place to post about this device. I originally posted regarding this on iFixit so see the details from that post below:
            "I'm hoping someone can give their opinion on the symptoms I'm seeing before I spend any more time and put money into this. I got this MacBook from a customer and after looking at it they decided they didn't want it.
            It doesn't turn on and there's no visual signs of life. I have tried resetting the NVRAM, SMC, power cycling, unplugging the battery, using the charger with the battery unplugged. Removed the...
            03-15-2024, 04:06 AM
