820-01700 burning battery flex cable
  • manubali
    • Feb 2017
    • 23
    • New Zealand
    Hey everyone, i was hoping if someone have seen this issue before.
    This unit came in with liquid damaged mainly on left side cd3217, nand circuit, T2 pmu and battery pcb, replacing above mentioned components and performing dfu revive fixed the issue, but its burning ground pins of battery flex cables (on battery pcb side).
    Diode values of data lines are normal and i have tested this on multiple batteries, so this is not faulty battery.
    i measured the voltage on those pins and it goes to around 1 volt and then it burns the cable
  • mon2
    • 14631
    Are you confident the flex cable is not being mated in the wrong direction from start to finish?
    • manubali
      • Feb 2017
      • 23
      • New Zealand
      Yes, flex cable connected properly, the connector size on battery pcb is smaller than the one on mlb, so no chance of wrong connection.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • emeskay
        Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
        by emeskay
        We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
        08-06-2024, 07:13 AM
      • mkdj
        by mkdj
        Mark and model: ASUS X571
        Tests already made:
        - I have removed...
        07-14-2025, 09:16 AM
      • techfreak9356
        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
        by techfreak9356
        09-14-2023, 11:10 PM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
