Lenovo NM-C861 backlight issue
  • rookieme
    • Oct 2014
    • 396
    • Greece
    the mainboard at first booted only sometimes with memory error.
    After ram rework it boots fine but the new issue is no backlight.
    Display did not had any issue so I guess something from the motherboard.
    At the JEDP1 I have 19V at pins 1 & 2, DISPOFF# at pin 15 is 0V and INVT_PWM at pin 16 is 2,82V.
    Same values are with lid closed.
    Lid switch works ok when tested with windows software.
    Is there something else I'm missing?
  • rogfanther
    • Jul 2006
    • 458
    • Brazil
    I believe DISPOFF# should not be low . But wait for other opinions also.
    • Bonzas
      • 470
      • Indonesia
      you forget pin 18 & 19 ?
      • rookieme
        • Oct 2014
        • 396
        • Greece
        +LCDVDD_CON [pins 18& 19] has 3,34V and I'm getting signal at display, backlight is missing
        • Cornito
          Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
          by Cornito
          Hello Team,
          I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
          Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
          Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
          08-08-2024, 08:09 AM
        • cheebster
          iPad Pro 12.9 5th Gen Backlight Issue
          by cheebster
          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
          Anyone...
          05-20-2025, 09:17 AM
        • Cornito
          TCL 65C715 backlight issue
          by Cornito
          Hello team,
          I'm back with another topic.
          It's a 65C715 TCL tv with backlight issue.
          But the problem is a bit strange.
          When I took this tv from the marketplace backlight didn't work but picture was ok.
          Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
          Putting all back together the tv worked fine for weeks. => Contact issue??
          Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
          06-09-2024, 02:24 AM
        • REpairAT
          Lenovo IdeaCentre AIO 520-27ICB Backlight issue
          by REpairAT
          got this AIO with a backlight issue, it just turns on for the blink of a moment.
          LED backlight stripes tested and working, no schematics available, also I couldn't find any datasheet of this responsible "554ALN" chip. I don't have a real routine with fixing these kind of issues, but maybe someone could give me a hint where to start.
          As soon as the computer is turned on, 20V on the LED output. When backlight turns on, Voltage rises to 50V as it should, but immediately starts to decrease to 20V again within 30sec.
          Picture of the backlight circuit and model numbers...
          05-09-2022, 11:44 AM
        • shellybelly
          Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
          by shellybelly
          Back Story
          I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
          So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
          08-27-2023, 10:40 PM
