Macbook air m1 can't access the recovery options by pressing and holding the power button
  • conghuyms
    • Apr 2022
    • 33
    • Vietnam
    I have an M1 MacBook Air (A2337) 2020 that came in for water damage and will not turn on. Upon opening it, I saw that the audio board was severely corroded. I disconnected it, and the device started working.
    After that, I dealt with the issues on the audio board by removing the capacitors that were shorted to ground, and the device started working. However, I encountered another problem: I can't access the recovery options by pressing and holding the power button. I'm not sure if it's a hardware issue or if the recovery partition has been lost. Currently, the system's time isn't updating, and it's stuck in 2020. I can't log in because there is a password. The device currently doesn't have an iCloud login, but I can't reset it since I can't access the recovery options.
    Please help me. Thank you so much.
  • conghuyms
    • Apr 2022
    • 33
    • Vietnam
    Pls Help me
    • reformatt
      • Feb 2020
      • 1411
      Have you checked the power button itself? It's directly underneath the audio board and connects through it. Better off replacing the board, they aren't that expensive. Check the connector for the power button and the flex itself. Don't assume because the MAC starts that it is working, because they auto power on when USB-C is connected usually.
      • conghuyms
        • Apr 2022
        • 33
        • Vietnam
        It's true that my MacBook automatically starts when I plug in a USB-C cable. However, when it's running, I can still shut it down by pressing and holding the power button, or turn it on by pressing the power button. The only issue is that pressing and holding the power button when turning it on doesn't allow access to the recovery options. There's no message on the screen. I don't know what to do next. Please help me.
        • anhbanxoi
          • Sep 2021
          • 172
          • VN
          Force DFU and restore with Apple Configurator
          • conghuyms
            • Apr 2022
            • 33
            • Vietnam
            Thank you verymuch
            • nikolayu
              MacBook Air A1932 internet recovery loop
              by nikolayu
              I have A1932 that is going to internet recovery every time.
              i tried nvram and smc reset but it looks that MacBook is not reacting to that.
              i tried to restore it through DFU but it restarts in the middle of process and Apple Configurator does not show any error, just stays like in progress.
              keyboard is working because I can connect to WiFi but internet recovery always fails with 2100 or 2003 error.
              also won’t open option to boot from usb device.
              and I noticed that is not possible to turn off the MacBook. It’s always turning on by itself.
              07-22-2025, 02:55 AM
            • cheebster
              Macbook Air 2020 A2179 Internet Recovery and Battery Issues
              by cheebster
              Hello, i have a batch of 10 Macbook Pros A2179 bought from a Costco return wholesaler.
              The 10 of them show the exact same behavior;
              They auto power on, to internet recovery spinning globe, fans to 100%.
              Power consumption on USB-C port is 0.43a, shuts down as soon as unplugged. Battery doesn't charge at all. However, it boots to 20V on the Ampmeter.
              Based on their iBridge versions (4.x and 5.x) these were shelfed for a long time.
              All of them power on the same way; 100% fans, shut down as soon as they are unplugged. Removing...
              10-09-2024, 06:23 AM
            • myth77
              macbook pro a2141 can not make recovery
              by myth77
              So, i dont know almost anything on macs..but this is my nephews so i had to try. Its 16 inch macbook pro from 2019...It all started when he left something on the keyboard when closing the mac and there it was the crack on screen. At first it was like working but later no. After that he told me that it wouldnt power on?...hear fans but nothing..tried like 100 of stuffs but nothing helped.
              So, he bring it to me...first i open it and figured he did also. there was lots of dust i cleaned everything...and started it...the broken screen showed only backlight but nothing on the screen. I...
              06-19-2022, 11:21 AM
            • MullySculder
              A1989 EMC3214 can't boot to USB drives due to T2 but SSD can't be initialized and Macbook freezes then reboots in recovery
              by MullySculder
              Hey folks, I'm working a 2018 13" Macbook Pro that I can't get to install an OS on.
              This was given to me by a friend who told me I could have it, if I fixed it.
              I've noticed a couple of dents on the laptop case and the touch bar doesn't have any activity lights when first turning on. When I boot up the machine, it gives a folder with a question mark. When I do eventually get to internet recovery with High Sierra, I can go to Disk Utility but I'll get errors when I try to erase the 512GB SSD. First Aid comes back with no issues. But if you linger too long on anything,...
              07-10-2024, 02:17 AM
            • envym
              MacBook Pro 2018 with Activation Lock
              by envym
              Hi everyone!
              I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
              I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
              06-27-2025, 08:54 AM
