a1707 5v stuck
  • Arshad alam4659
    • Aug 2020
    • 157
    • India
    a1707 5v stuck
    i have a motherboard a1707 820-00928-a this board is 5v in stuck and restart again and again all ldo is present ppbus_g3h is 0v no short pp3v3_g3h is 3.3v smc_bc_acok is 3.3v but problem is all voltage is not stable like pp3v3_g3h voltage jumps 3.3v and 2.1v sometime 1.5v and dc also showing 5v then 0v then 2.5v not fixed
    This board was working a day before, the customer came to install the battery, after installing the battery it started working but the next day it is not working
  • 1centchips
    • Feb 2016
    • 41
    Check with the original battery that was removed from the laptop. See if you can reproduce the issue with the used battery.
    • Arshad alam4659
      • Aug 2020
      • 157
      • India
      Forgot the old battery and trying to boost above 5v with new battery but not getting 20v
      • charles75328
        • May 2024
        Hi did you checked the U2890 and UB090?
        • Arshad alam4659
          A1707 5V STUCK
          by Arshad alam4659
          macbook a1707 820-00928-a no liquid damage 5v stuck i checked some voltage
          PP3V3_G3H=3.4v
          PPVIN_G3H_P3V3G3H=4.7v
          PPDCIN_G3H=5v
          PP1V8_UPC_TB_LDOD=1.79v
          PP3V3_UPC_TB_LDO=3.3v
          PP1V1_UPC_TA_LDO_BMC=1.1v
          PPBUS_G3H=0v no shorting to ground
          what should Icheck next...
          11-14-2024, 07:59 AM
        • Stunt
          Hp Laptop Stuck on Hp protected by hp sure start screen
          by Stunt
          Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
          I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
          I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
          Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
          screen that's it and stuck there. I left it until the following day and i still...
          09-02-2025, 01:51 PM
        • vanromic
          Macbook a1707 - 3 ports cycling and 1 stuck on 5v
          by vanromic
          Hello! I'm trying to resuscitate a Macbook that the local tech gave up on. I have the board view and schematic and have the main board out of the case.
          Of the 4 usb-c ports, 3 cycle at 5V - they all go up to about 1.5A, then seem to switch off, back to 5V 0A, up to 1.5A, and off again. The cycle lasts a few seconds - maybe 3s.
          The 4th port doesn't cycle and draws ~0.5A at 5V consistently. It seems it's the port linked to U3100 - it's on that side of the board and is the port closest to the battery and the CD3215C00 chips.
          I've read that the CD3215s are...
          05-01-2024, 06:46 AM
        • JasonC89
          Macbook Pro A1707 820-00281 Stuck @5V
          by JasonC89
          So I have an Macbook Pro that came in for no power (I dont do a lot og Macbook repairs). After some testing I found it was only getting 5V with very little current draw, if any.
          I searched around for shorts, and didnt find any. No real signs of liquid damage etc.
          Following a couple of questions from other members here I was able to further test voltages etc. Im now at a point where PP3V3_G3H is showing, but only at 2.23V.
          I have 5v on the Enable pin.
          Also the dual diode D6902 is showing :
          5.19V @ Pin 1
          0v @ Pin 2
          4.15V @ Pin 3
          L6900...
          04-10-2024, 07:03 AM
        • stormanimal83
          Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
          by stormanimal83
          Hey....
          Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
          my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can“t understand...
          01-18-2024, 02:15 PM
