A1707 5V STUCK
  • Arshad alam4659
    • Aug 2020
    • 156
    • India
    A1707 5V STUCK
    macbook a1707 820-00928-a no liquid damage 5v stuck i checked some voltage
    PP3V3_G3H=3.4v
    PPVIN_G3H_P3V3G3H=4.7v
    PPDCIN_G3H=5v
    PP1V8_UPC_TB_LDOD=1.79v
    PP3V3_UPC_TB_LDO=3.3v
    PP1V1_UPC_TA_LDO_BMC=1.1v
    PPBUS_G3H=0v no shorting to ground
    what should Icheck next
  • mon2
    • 14575
    PPBUS_G3H=0v
    Check both sides of the fuse on PPBUS_G3H to confirm the fuse is not blown.
    What is the current draw of the 5v? Each CD3215 must be inspected and measured for their local LDO rails.
    These webpages are applicable:
    https://logi.wiki/index.php/CD3215_Bootup_Sequence
    https://repair.wiki/w/MacBook_Pro_A1..._of_20V_repair
    https://boards.rossmanngroup.com/thr...-on-usb.60302/
    https://www.youtube.com/watch?v=EOtK9UWM3pk
    • Arshad alam4659
      • Aug 2020
      • 156
      • India
      i checked this sequence
      PP20V_USBC_XB_VBUS =5v
      PP3V3_UPC_XB_LDO=3.3v
      PP1V8_UPC_XB_LDOA=1.79v
      PP1V8_UPC_XB_LDOD=1.79v
      PP1V1_UPC_XB_LDO_BMC=1.1v
      HV_GATE1= not checked because under the cd 3215
      HV_GATE2=not checked because under the cd 3215
      PPDCIN_G3H=5v
      TBA_VDDA=5v
      PM_EN_P3V3_G3H=5v
      PP3V3_G3H=3.4v
      PP1V2_S5_SMC_VDDC=1.2v
      PP3V0_S5_AVREF_SMC=2.9v
      SMC_RST_L=3.4v
      SMBUS_SMC_4_G3H_SCL=0.131v
      SMBUS_SMC_4_G3H_SDA=0.620v
      USBC_XB_CC1=0v
      USBC_XB_CC2=1.4v
      PP20V_USBC_XB_VBUS=5v
      TBA_AUX_DET=1.2v
      • mon2
        • 14575
        Check both CD3215 as per the linked article. UB300 & UB400.
        • Arshad alam4659
          • Aug 2020
          • 156
          • India
          please quote me which article
          • mon2
            • 14575
            • Arshad alam4659
              • Aug 2020
              • 156
              • India
              sorry for my english is not good
              i changed both cd3215 ub 300 and ub 400 now board is ok but i have a question how to confirm which side cd3215 is bad all port same behaviour also all ldo ok
              all chip are in sequence 9 are ok but sequence 10 (SMBUS_SMC_4_G3H_SCL= 0v)
              Do I need to change them all at once?
              • mon2
                • 14575
                Remove all power. Measure the resistance to ground on SMBUS_SMC_4_G3H_SCL.
                What is the resistance in ohms?
                • Arshad alam4659
                  • Aug 2020
                  • 156
                  • India
                  my board is now ok problem is solved cd3215 was bad
                  SMBUS_SMC_4_G3H_SCL​=90k (no shorting was here)
                  My question is how to confirm which cd3215 is bad if all cd3215 are in the same condition I have to pick them all up and check them
                  • mon2
                    • 14575
                    I would suggest to remove all power -> meter in DIODE mode -> red meter probe to ground (yes ground) -> black meter probe to point to test.
                    Test each and every CD3215 on the board to hunt for a part with a different reading than others. Often, the diode mode measurement will reveal the defective CD3215. You can study the diode mode measurements from the websites / schematics(?) to obtain the good diode measurement ranges.
                    • Arshad alam4659
                      • Aug 2020
                      • 156
                      • India
                      thanks for help
                      • Arshad alam4659
                        a1707 5v stuck
                        by Arshad alam4659
                        i have a motherboard a1707 820-00928-a this board is 5v in stuck and restart again and again all ldo is present ppbus_g3h is 0v no short pp3v3_g3h is 3.3v smc_bc_acok is 3.3v but problem is all voltage is not stable like pp3v3_g3h voltage jumps 3.3v and 2.1v sometime 1.5v and dc also showing 5v then 0v then 2.5v not fixed
                        This board was working a day before, the customer came to install the battery, after installing the battery it started working but the next day it is not working
                        10-09-2024, 08:56 AM
                      • Stunt
                        Hp Laptop Stuck on Hp protected by hp sure start screen
                        by Stunt
                        Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                        I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                        I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                        Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                        screen that's it and stuck there. I left it until the following day and i still...
                        09-02-2025, 01:51 PM
                      • vanromic
                        Macbook a1707 - 3 ports cycling and 1 stuck on 5v
                        by vanromic
                        Hello! I'm trying to resuscitate a Macbook that the local tech gave up on. I have the board view and schematic and have the main board out of the case.
                        Of the 4 usb-c ports, 3 cycle at 5V - they all go up to about 1.5A, then seem to switch off, back to 5V 0A, up to 1.5A, and off again. The cycle lasts a few seconds - maybe 3s.
                        The 4th port doesn't cycle and draws ~0.5A at 5V consistently. It seems it's the port linked to U3100 - it's on that side of the board and is the port closest to the battery and the CD3215C00 chips.
                        I've read that the CD3215s are...
                        05-01-2024, 06:46 AM
                      • JasonC89
                        Macbook Pro A1707 820-00281 Stuck @5V
                        by JasonC89
                        So I have an Macbook Pro that came in for no power (I dont do a lot og Macbook repairs). After some testing I found it was only getting 5V with very little current draw, if any.
                        I searched around for shorts, and didnt find any. No real signs of liquid damage etc.
                        Following a couple of questions from other members here I was able to further test voltages etc. Im now at a point where PP3V3_G3H is showing, but only at 2.23V.
                        I have 5v on the Enable pin.
                        Also the dual diode D6902 is showing :
                        5.19V @ Pin 1
                        0v @ Pin 2
                        4.15V @ Pin 3
                        L6900...
                        04-10-2024, 07:03 AM
                      • stormanimal83
                        Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                        by stormanimal83
                        Hey....
                        Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                        my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                        01-18-2024, 02:15 PM
