Macbook a1707 - 3 ports cycling and 1 stuck on 5v
  • vanromic
    • Apr 2024
    • South Africa
    Hello! I'm trying to resuscitate a Macbook that the local tech gave up on. I have the board view and schematic and have the main board out of the case.
    Of the 4 usb-c ports, 3 cycle at 5V - they all go up to about 1.5A, then seem to switch off, back to 5V 0A, up to 1.5A, and off again. The cycle lasts a few seconds - maybe 3s.
    The 4th port doesn't cycle and draws ~0.5A at 5V consistently. It seems it's the port linked to U3100 - it's on that side of the board and is the port closest to the battery and the CD3215C00 chips.
    I've read that the CD3215s are configured as master-slave and I'm guessing that the 3 that are cycling are somehow failing to initialize and that U3100 might be the problem, or the problem is in the sub-circuit for that port.
    If anyone out there is familiar with this board and / or this particular failure mode and could give me some pointers in terms of troubleshooting before I rush out and by a new CD3215C00, I'd be grateful - thanks!
  • mon2
    • 14250
    Test the voltage to ground of each such cd3215's LDO power rail. Check the schematics to locate the power rail for each part and confirm they are present. Post the list of measurements for each.
    Each cd3215 must be working to allow for the 20v power delivery contract negotiation.
    reference:
    https://logi.wiki/index.php/CD3215_Bootup_Sequence
    With no power, meter in resistance mode, measure the resistance to ground of each inductor. Usually are grey in color. Post each resistance in ohms. Checking for shorted parts on that local power rail. Often a shorted capacitor.
    What is the voltage to ground of ppbus_g3h?
    • vanromic
      • Apr 2024
      • South Africa
      PP3V3_UPC_XB_LDO is 3.24V for U3100, 0.37V for UB300, 0.26V for UB400, 0V for U3200.
      PP3V3_G3H is 0 or close to it on all four cd3215s. From watching too many Louis Rossmann vids, this is a bad thing...
      Still working my way through the inductors - there are many and some are tiny.
      Unfortunately I need to leave this until the weekend - I'll post L values then. Thanks for your help!!
      • mon2
        • 14250
        Ok, some issues there. With no power, measure the resistance to ground of each power rail that is not matching the schematic values.
        The requested rail was PPBUS_G3H.
        Measure the voltage to ground of this critical power rail. If it is not within specifications, remove all power and measure the resistance to ground of this power rail.
        • reformatt
          • Feb 2020
          • 1414
          5V @ 1.5 amps seems way too high. Make sure you have battery disconnected during these kinds of tests.
          Check resistance to ground for the PPBUS_G3H and PP3V3_G3H rails. As the board has been worked on by someone else, there can also be an introduced fault so recheck all board rework first.
          • Aliencomputres
            • Aug 2019
            • 208
            • România
            change both CD3215C00 !
            • vanromic
              • Apr 2024
              • South Africa
              On looking over this logic board in a little more detail, I've noticed that Q3100, a dual mosfet FDPC4044 is missing and must have removed by the tech who worked on the board.
              I don't want to waste the time of those on this forum and am first going to see if I can get hold of this chap to find out exactly what work he did, so that I can try to get the board back to at least having all the components it needs. I noticed an inductor missing as well, but am not sure whether he removed it, or if the board was fabricated without it.
              I feel it's best to pause this thread for now until the board is in a better state. Thanks to all who have tried to help so far!!
              • JasonC89
                Macbook Pro A1707 820-00281 Stuck @5V
                by JasonC89
                So I have an Macbook Pro that came in for no power (I dont do a lot og Macbook repairs). After some testing I found it was only getting 5V with very little current draw, if any.
                I searched around for shorts, and didnt find any. No real signs of liquid damage etc.
                Following a couple of questions from other members here I was able to further test voltages etc. Im now at a point where PP3V3_G3H is showing, but only at 2.23V.
                I have 5v on the Enable pin.
                Also the dual diode D6902 is showing :
                5.19V @ Pin 1
                0v @ Pin 2
                4.15V @ Pin 3
                L6900...
                04-10-2024, 07:03 AM
              • leonemax81
                Macbook a1707 820-00281 Battery no Power
                by leonemax81
                Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                08-23-2024, 09:24 AM
              • Bmet
                MacBook Pro 13 inch A2238 M2 stuck on 5V
                by Bmet
                I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
                04-02-2025, 05:02 PM
              • sofles
                Macbook a1707 2017 model 820-00928 GPU issue
                by sofles
                Hello there
                I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                11-21-2024, 05:25 AM
              • dbuergi
                MacBook A2141 one USB port dead and one power cycling
                by dbuergi
                I got a 16inch MacBook Pro showing 5v and 0,3a on the left ports and right side has one power cycling and one showing nothing. The one cycling shows 30c under thermal camera. Surrounding components show no corrosion or any shorts.
                Any ideas what to check next? The whole board looks clean compared to the other A2141s i saw....
                04-25-2025, 11:40 AM
