Toshiba A205-S5825 regular shut down at start up
  • kamel
    • May 2011
    • 127
    • TUNISIA
    Hi! An urgent help is needed for Toshiba A205-S5825 regular shut down issue.
    Platform : ISKAA LA-3481P Rev : 2A
    Steps already taken :
    1-cleaned fan system (was a little dusty but not clogged), removed dried paste and applied new one to CPU and GPU.
    2-Tried naked mobo with a working ram, CPU, KB and Lcd display, enter bios screen, lap always shut down after about 1'50s.
    3- Scanned mobo with an infra-red thermometer, Max temperature registred 42° at SB, so no heat issue.
    4- Checked Thermal Sensor ADM1032ARM :
    VDD : 3Vs
    D+ 2.38V
    D- 0v
    EC_SMB_CK2 and _DA2 : 5.6V each
    pin 4 "Therm#" and 6 "Alert#" not connected.
    Please note that CPU of A205-S5825 series doesn't use big "Nec-Tokin cap" but 330uf small caps.
    Also Tried with Mobo +ram +fan but without CPU it also shut down at about same time.
    Has any one dealt with the same issue, or any clue as where to dig further
    Thank you
  • atsio
    • Oct 2013
    • 819
    • Greece
    Re: Toshiba A205-S5825 regular shut down at start up
    Probably problem with GPU. Try a reflow.
    • kamel
      • May 2011
      • 127
      • TUNISIA
      Forgot to mention, that I did GPU reflow with no avail.
      • atsio
        • Oct 2013
        • 819
        • Greece
        If you had a reflow and didn't resolved it then do a reball.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3610
          • slovakia
          try to work without adapter only on battery. if it work, it is TOKIN capacitor
          • lezsimply
            The Wanderer
            • 647
            • Philippines
            already mentioned there's no nec tokin cap
            • helderfb
              • May 2014
              • 16
              • portugal
              Flash bios chip.
              • kamel
                • May 2011
                • 127
                • TUNISIA
                Originally posted by helderfb
                Flash bios chip.
                The idea of flashing bios came to my mind, but time before lap shuts down seems to be short and risky for bios flashing : only 1min50s! Do you agree ?
                • loser18
                  • Nov 2013
                  • 274
                  Flash bios chip.
                  It has got nothing to do with bios...
                  Why everybody think that BIOS is some magic box which can fix everything???
                  Yes, it will even cure a cancer,lol...
                  Laptop clearly posts...
                  I would start with gpu reball...
                  • SteveNielsen
                    Retired Tech
                    • 2327
                    Loser18 is right. It's not the BIOS or it wouldn't get as far as it does.
                    I also don't understand why people think firing up a board without the CPU is going to show them anything useful. Am I missing something about that?
                    • loser18
                      • Nov 2013
                      • 274
                      Don't need to use CPU when checking other voltages (and therefore states where the mobo is) On the other hand, how would you measure CPU voltages if it's in socket???
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        Why can you not measure CPU voltages when the CPU is in the socket?
                        • loser18
                          • Nov 2013
                          • 274
                          I didn't mean voltages of cpu regulator...I was talking about signals such a cpu reset or power good etc...I don't know about any other way than check socket pins themselfs...pretty sure there's no other way,lol...
                          • SteveNielsen
                            Retired Tech
                            • 2327
                            Of course that makes sense but that's not what I meant. I meant as a general troubleshooting technique people seem to think that firing up the MB without the CPU to see what it does is going to tell them anything useful and that's what I read people doing. No mention of checking socket pin voltages.
                            BTW, I don't mean that in any insulting way, I just don't understand it.
                            • loser18
                              • Nov 2013
                              • 274
                              99% of people on this forum has absolutely no clue how the laptop mobo works...I'm not saying that I know either...In some cases I've fixed several (2 or 3)mobos by taken out the CPU and start up without it...Still don't understand what was going on though...
                              • SteveNielsen
                                Retired Tech
                                • 2327
                                More likely it was re-seating the processor that fixed the problems. The MB is basically a collection of parts without the CPU. It may blink or yell at you without a CPU but not much else.
                                I've got decades of computer tech experience but I'm retired now and have been out of the loop for the last 4 years so I don't know what new-fangled crap they've come up with nowadays
                                • dj_ricoh
                                  • 2073
                                  there is something like this
                                  i dont know if there is for notebook
                                  • loser18
                                    • Nov 2013
                                    • 274
                                    It wasn't that simple case...The mobo had "blink" code which indicated CPU fault...so replaced with my spare one for testing (100% working) but the same fault appeared...So took another 100% working board, but again the same fault with booth CPU's...I didn't understand what was going on, so googling & found solution to start the bad mobo without cpu, but with mems in...then remove mems & seat cpu...after that got 3 "blink" codes (mem failure obviously)...seat mems & started up...I've had to do the same procedure with 2nd CPU to get it working again...Think that the bad mobo got both CPU's in some weird state,which prevent the CPU to start up...Even in another board...I've sold the mobo to friend of mine & as far as I know it's still OK...As far as I remember those were DV5's with AMD CPU...Still can't understand what was going on & yes I've reseated mem's before but never think to start without CPU but mems...
                                    Yeah...I've seen those...You got tons of gadgets in China...
                                    They even selling kits for nearly all CPU's and mem's (also for laptops)
                                    Anyway...I think we hijacked this thread & the guy needs to fix his laptop,lol...
                                    • SteveNielsen
                                      Retired Tech
                                      • 2327
                                      Yeah, that is a very different situation there and quite interesting. I think you're probably right. Something happened to put the CPUs in that state and it was cleared after discharge and power cycles. I've seen some strange things similar with no solid explanation. Some things we can only guess about but it is entertaining and educational.
                                      The hijack was unintentional. Sorry.
                                        09-06-2024, 05:27 AM
                                        09-06-2024, 05:59 AM
                                        09-06-2024, 05:33 AM
