Macbook Air A2337 not turning on - ISL or CD issue?
This topic has been answered.
  • tomtom67
    replied
    LDOs on the CD3217 are fine; I found R5215 had non-measurable resistance, preventing the ISL to recognize a plugged charger.
    Now at 5V / 7 - 30 mA, but with super short peaks to 2A every ~20s (as of the PLD Amp-Meter).
    Found Q5230 short pins 1+2, swapped that and also Q5240. After a longer waiting time, finally the MacBook turns on and boots
  • mon2
    replied
    Check the LDO rails on each CD3217.
    CD3215 Bootup Sequence - LogiWiki
  • tomtom67
    replied
    After thinking a bit longer, i think both GATE_Q1 and GATE_Q2 should oscillate. Will find another donor tomorrow to transplant the third ISL on that board. Didn't find any shorts, and diode readings around the isl are ok, too.
  • Macbook Air A2337 not turning on - ISL or CD issue?
    Have an A2337 here, which suffered some serious coffee damage. After cleaning C5220 fell from the board, so I replaced it and after lifting the ISL I found pad C5 was also partially corroded, first reballed the original ISL (no power), and then replaced it from a donor.
    I now get 5V / ~10mA stable on the charger, and found the CHGR_GATE_Q2 (GATE_Q2 on the ISL) doesn't get activated (Q1 does).
    Is this an ISL or a communication issue (perhaps with the CD3217s)?
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    🛠 Original Issue
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
  • saisoni20
    MacBook Air A2337 820-02016-07 No sound ISSUE
    by saisoni20
    I have A2337 MacBook Air no sound issue.
    I have replaced new Audio Board but still same issue. I went through repair wiki and checked critical voltages.
    In terms of voltages, I have following voltages,
    1 PP1V25_AWAKE_IO - 1.2V
    2 PP1V25_AWAKE_IO - 1.8V
    3 SPKRAMP_A_OUTP_R - 0V
    ​4 SPKRAMP_A_OUTN_R - 0V
    Am I missing any other critical voltages?
    07-28-2024, 05:53 PM
  • drlarsen
    MacBook Air M1 A2337 battery/charging issue
    by drlarsen
    Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
    I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
    On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
    After some hours, the battery status did not improve. Restore via DFU did not help.
    I connected the power adapter to a Kill-a-Watt...
    07-17-2025, 02:35 PM
  • pcbmaniac
    MacBook A1278 (3115) No PPBUS_G3H Issue
    by pcbmaniac
    Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
    I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
    1. U7000 Measurements:
      • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
    2. Resistors:
      • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
    Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
    • If I also decide to replace the SMC, do I need to order it pre-programmed,
    12-02-2024, 04:12 PM
  • sofles
    Macbook a1707 2017 model 820-00928 GPU issue
    by sofles
    Hello there
    I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
    I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
    11-21-2024, 05:25 AM
