Hey everyone!
I have a MacBook Pro A1989 with a 820-00850-A board that recently stopped working. I used it overnight to charge my phone, in the morning it didn't turn on, I assumed flat battery but now won't charge and doesn't start at all.
I have fully dissassembled it, when disconnected the battery reads at 0.012V. Even with the battery disconnected the laptop doesn't boot.
The diode voltages around all 4 CD3215's seem fine.
For all CD3215 (UB300, UB400, U3100 and U3200) I read just above 5V on PP20V_USBC_TA_VBUS, 3.3V on PP3V3UPC_TA_LDO, 1.8V on both PP1V8_UPC_TA_LDOD and PP1V8_UPC_TA_LDOA, and 1.1V on PP1V1_UPC_TA_LDO_BMC (TA being then TB, XA and XB respectively).
The voltages on the transistors seem low from what I'm seeing on the OpenBoardData for that board (the guide says "~26V"):
The switching to 20V on the USB-C doesn't seem to happen though. I don't have a USB power meter so I'm unsure how much current is being drawn from the 5V on the USB.
I also measured the voltage on PPBUS_G3H and got 12.3V.
I am not seeing any obvious signs of damage. No component seem to be heating up excessively (don't have a thermal camera so mostly going by feel). I think I can feel the T2 chip being slightly warmer than ambiant / the rest of the components but hard to know for sure, and nothing drastic.
I am unsure whether these measurements are enough to diagnose anything, or if there are any additional measurements I can do to further troubleshoot.
I have access to a multimeter, oscilloscope, signal generator and bench power supply (30V / 5A). I do technically have a soldering station and SMD rework gun, however they're really not the best quality and I don't trust them much, so if possible I want to avoid unnecessarily soldering/desoldering things as there is a high chance that I fry other components in the process due to the sheer amount of heat I sometimes have to output to get a result.
Any help would be greatly appreciated.
Thanks,
Erin
| GATE1 (pin 1) | GATE2 (pin 4) | |
| TA (QB300) | 10.9V | 7.8V |
| TB (QB400) | 10.9V | 7.8V |
| XA (Q3100) | 10.8V | 7.6V |
| XB (Q3200) | 10.9V | 7.8V |
Thanks,
Erin
