Asus N550JV rev 2.1 motherboard ... no more power after shutdown...
  • rui4892
    • Mar 2017
    • 57
    • Portugal
    hello forum
    I have this board on the bench... it works fine and ok when it is started for the first time and without RTC battery... then Windows works fine with all peripherals connected without any apparent problem... but when I give the order to turn it off it never turns on again... the voltage on the power key is stable at 3.3v and goes to 0 when pressed, this information reaches the IO on pin 110 correctly... the only way to turn the machine back on is to remove the battery and disconnect the charger.
    Thanks... Rui.
    Link to boardview --> https://www.badcaps.net/forum/troubl...50jv-boardview
  • rui4892
    • Mar 2017
    • 57
    • Portugal
    hello again, However, I bought the IO from a trusted supplier, but the symptom persists...so I need some clues...thanks
    • rui4892
      • Mar 2017
      • 57
      • Portugal
      however, with the help of boardview I verify that the P_1VS8_PWRGD and 1.35V_PWRGD have a very low resistance (around 10 ohm) after turning off the machine. With the removal of the PU8300 the symptom of not turning it back on remains but with the removal of the PU8600 the machine stopped turning off or rather it turns off and then turns back on again, I have already ordered these components to be replaced, I hope for news soon.
      • glovecaps
        by glovecaps
        11-25-2024, 04:23 PM
      • dhenion
        Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
        by dhenion
        I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
        The original board was:
        ASUS X510UNR REV 3.0 A
        The replacement board is:
        ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
        It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
        01-30-2024, 01:45 PM
        ASUS P5GC-MX motherboard recap
        by momaka
        Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
        This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
        So here is what the motherboard looked like with its original caps:
        CPU VRM area up close…...
        01-27-2021, 11:59 PM
      • MakNCheese
        ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
        by MakNCheese
        I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
        Symptoms:
        • Severe lag across the system, including BIOS navigation.
        • Slow boot times and unresponsive performance in Windows.
        • Battery charges very slowly (e.g., ~5% in 2–3 hours).
        • No error messages or BSODs, just extreme sluggishness.
        What I've Tried:
        • Replaced
        06-04-2025, 12:48 AM
      • Pedro Ramírez
        BIOS on an Asus Prime H310M-E R2 motherboard
        by Pedro Ramírez
        Hi friends, I need help with the BIOS on an Asus Prime H310M motherboard - E R2, no video when turned on. I've attached the original backup....
        07-29-2025, 04:18 PM
