SOny MBX-216 3.3V lost
  • tomodachi
    • Apr 2012
    • 611
    • Turkey
    No any short, liquid spill or drop. This unit generates 3.3V (on pwr button) but when power button pressed it goes and to recover it I have to keep it unplugged for a while.
    EC bios flashed but no change, checked all mosfets and capacitors to the ground, can't find any short or open please give me some suggestions.
  • tomodachi
    • Apr 2012
    • 611
    • Turkey
    Re: SOny MBX-216 3.3V lost
    any suggestions ?
    • tomodachi
      • Apr 2012
      • 611
      • Turkey
      some assistance please
      • learnix
        • Dec 2012
        • 23
        • malaysia
        please drill down further , are you facing this when battery is connected ? or you are testing with only power adapter ?
        have you tried using only battery or power adapter to identify the behavior ?
        • lord
          • May 2011
          • 319
          • Croatia
          What do you have on pin 23 on the WPC775L after you press the power button?
          Do you have voltage on the power button?
          • atsio
            • Oct 2013
            • 819
            • Greece
            First check resistance to ground on all coils. What are the voltages on pins 123, 96, 25, 26, 27, 108, 93, 23, 19 and 11 of U18?
            The best way to check voltage strength in situations like this is with an oscilloscope due to poor sampling rate of DMM.
            • whaldsz
              • Apr 2013
              • 395
              • Philippines
              what do you get at pin 20, pin 15 and pin 123 of SIO before and after pressing the power button?
              • tomodachi
                • Apr 2012
                • 611
                • Turkey
                With or without battery issue is same. I m using a lab type power supply.
                when I connect psu to motherboard I read 0.01 ampers then I press power button and amper indicator drops to zero and 3.3V gets lost from power button.
                Sorry I can't measure those pins because daughter board blocks it when plugged. but there is 3.3V at power button before pressed. when pressed it goes to 0.
                See; Without daughter board
                with daughter board
                there is no short in all coils, I m pretty sure about that. and as I said above I can't measure voltages of SIO
                • atsio
                  • Oct 2013
                  • 819
                  • Greece
                  You can check all the signals on other smt components on the board. I.E. PM_SLP_S3# on R318 and D19, SUSON on PQ17, PR119, pin 3 of U56, etc.
                  Just follow the schematic.
                  • con55
                    • Feb 2014
                    • Greece
                    Hello
                    What is a good measure from the coil to ground? and when do i know when there is a short from the coil to ground?
                    • sebuncle
                      • Jun 2010
                      • 46
                      • France
                      Hi
                      i have similar problem do you solved the problem ?
                      JOVY RE7500
                      • mahmoodjavan
                        Banned
                        • Mar 2018
                        • 584
                        • iran
                        Originally posted by tomodachi
                        no any short, liquid spill or drop. This unit generates 3.3v (on pwr button) but when power button pressed it goes and to recover it i have to keep it unplugged for a while.
                        Ec bios flashed but no change, checked all mosfets and capacitors to the ground, can't find any short or open please give me some suggestions.
                        bios
                        • DynaxSC
                          Extreme High Current & Low Voltage Short Killer ??
                          by DynaxSC
                          Hi Folks
                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                          After taking off the socket, the shorts dissappear again.
                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                          10-15-2024, 10:13 AM
                        • Stephen
                          MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                          by Stephen
                          I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                          02-06-2025, 12:03 PM
                        • Carlos#2003%
                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                          by Carlos#2003%
                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                          02-15-2024, 07:52 PM
                        • adelfr2009
                          HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
                          by adelfr2009
                          I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
                          After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
                          09-28-2025, 10:21 PM
                        • Victor Moreira Silva
                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                          by Victor Moreira Silva
                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                          Well, my decice specs are the following:
                          Model: Acer Nitro 5 AN517-54-55T5
                          CPU: Intel Core i5-11400H
                          GPU: NVIDIA GeForce GTX 1650
                          Motherboard: GH51G LA-L181P Rev:1c
                          The symptom:
                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                          05-26-2025, 10:49 AM
