Macbook A2289 820-01897does not charge.
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    The MacBook works completely on battery power but does not charge! When the battery is connected, the lower USB port stops working (without the battery, all 4 ports work with a consumption of 5 V/0250 A (not stable)).
  • mon2
    • Dec 2019
    • 14657
    Test the resistance (with no power) of the battery charge leg (current sense) of the charger IC. Does the measurement match the schematic resistance values?
    • PITERPENY
      • Jul 2023
      • 461
      • Ukraine
      CD3217
      • PITERPENY
        • Jul 2023
        • 461
        • Ukraine
        By the way, I removed a pair of CD3217 from a MacBook Air A2179! They are interchangeable!
        • phantomEVO
          • Mar 2013
          • 507
          what do you mean?
          • PITERPENY
            • Jul 2023
            • 461
            • Ukraine
            Originally posted by phantomEVO
            what do you mean?
            • techfreak9356
              Vostro 3400 (LA-K033P) won't charge battery, everything else ok
              by techfreak9356
              I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
              09-14-2023, 11:10 PM
            • razenxd
              How can I charge that battery pack?
              by razenxd
              it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
              At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
              Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
              Now, I have noticed a few things.
              The "dead" battery, while connected to charger and NOT Charging will...
              12-05-2024, 06:11 AM
            • ruletero
              Acer a515-43 low battery charge voltage
              by ruletero
              Hi
              Acer A515-43
              LA-H801P
              Fail: Does not charge battery, has low voltaje on connector.
              Laptop didn't want to turn on, only charge led blinked.
              I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
              I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
              Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
              10-24-2022, 02:31 PM
            • ACS-Repair
              MacBook Air 2014 battery will not charge
              by ACS-Repair
              Hello All,
              I have a unusual problem with a MacBook Air 2014 820-3437 that it will not charge the battery. I have 2 batteries that charge just fine in another 820-3437 so i assume that the batteries themselves are OK. One was new in 2020.
              This board started off as a PP3v3_S5 short that was resolved (shorted capacitor) and came to life fine. While testing the computer I noticed that the battery was not charging so I checked the following components:
              Current sensing:
              R7121 10 ohm
              R7122 10 ohm
              R7151 2.2 ohm
              R7152 0 ohm
              06-15-2023, 11:15 AM
            • Juan Carlos Medina Franca
              Macbook air m1 does not charge the battery
              by Juan Carlos Medina Franca
              Hello, I have a MacBook Air M1 that got water on it and now the computer does not charge the battery. The USB C port does work since I can connect the computer to HDMI for example. The battery also works well since if I connect a motherboard from another MacBook Air M1, the battery charges.
              Anyone know what can it be?​
              06-18-2024, 11:28 AM
