C850D beep no ram but no boot no image
  • Learn2Day
    • Jun 2013
    • 254
    • Portugal
    Hey,
    I just got a C850D that turns on but no image and doesn't boot. But it gives me beep error with no RAM in it.
    Could this be BIOS? I have a spare board of exact same model I can replace BIOS with, but before that, is there any BIOS recovery procedure available for this?
    Thanks.
    Galaxy S6 Edge x2 (Gold&White)
    Asus GL552VW-i7 6700HQ|GTX 960M|15.6"FHD|16GB DDR4|512GB M.2 SSD+1TB SSD
    Clevo W230SD - i7 4710MQ|GTX960M|13"QHD+|16GB DDR3L|500GB+256GB mSATA SSD+1TB HDD
    Try Harder!
  • atsio
    • Oct 2013
    • 819
    • Greece
    Re: C850D beep no ram but no boot no image
    First try another CPU.
    • Learn2Day
      • Jun 2013
      • 254
      • Portugal
      Another CPU didn't worked. Also might be worth mentioning I hear a short crackling sound coming from the speakers when I turn on laptop.
      Try Harder!
      • Learn2Day
        • Jun 2013
        • 254
        • Portugal
        CPU, GPU and NB are heating up significantly. But after a few seconds fan kicks in and the seem to hold their temperature in check.. In a minute or so laptop turns off but it's hard to say if this is related to temp or not, considering you have no visible boot.
        What do you guys think, should I start with BIOS or just do a quick reflow to see if it boots? I usually like to avoid reflow until all options are exhausted, I'm always afraid to damage the board.
        Thanks.
        Try Harder!
        • atsio
          • Oct 2013
          • 819
          • Greece
          measure voltages on all pins of lvds.
          • Learn2Day
            • Jun 2013
            • 254
            • Portugal
            pins 3, 35, 37, 39 - 3.3V
            pins 2, 4 - 19V
            all other pins read virtually 0V.
            Didn't mention before but I did test laptop both with display and external.
            Thanks.
            Try Harder!
            • atsio
              • Oct 2013
              • 819
              • Greece
              What is the model of the motherboard?
              • Learn2Day
                • Jun 2013
                • 254
                • Portugal
                Not quite sure.
                Seems to be PLAC/CSAC DSC REV:2.1
                thanks
                Try Harder!
                • Learn2Day
                  • Jun 2013
                  • 254
                  • Portugal
                  Can someone help me find the schematics and locating BIOS chip on this model?
                  Thanks.
                  Try Harder!
                  • atsio
                    • Oct 2013
                    • 819
                    • Greece
                    Your are looking for Pegatron PLAC/CSAC DSC REV:2.1 which is quite difficult to find.
                    • Learn2Day
                      • Jun 2013
                      • 254
                      • Portugal
                      Do you think it might be corrupt BIOS? I don't think it's GPU related, with GPU probably wouldn't even post beep errors.
                      Try Harder!
                      • atsio
                        • Oct 2013
                        • 819
                        • Greece
                        You will never know until you try it
                        • Learn2Day
                          • Jun 2013
                          • 254
                          • Portugal
                          Can you help locate BIOS chip? I'm all that much noob..
                          http://www.filefactory.com/file/5sjs...AC_DSC_2.1.rar
                          Thanks.
                          Try Harder!
                          • lezsimply
                            The Wanderer
                            • 645
                            • Philippines
                            On pic 002, left side near memory card reader beside ati chip. Its labeled winbond which I think is a 200mil soic.
                            • Learn2Day
                              • Jun 2013
                              • 254
                              • Portugal
                              Thank you lezsimply!!
                              Try Harder!
                              • Learn2Day
                                • Jun 2013
                                • 254
                                • Portugal
                                Hey, I really need your help..
                                I replaced BIOS chip with the spare one I had and tadaaa!! It worked!
                                After this I re-assembled the laptop, powered it on, entered BIOS, changed the time and saved it. Got no media error due to formatted hdd, rebooted to boot Win instalation and it froze! Now it won't turn on or even light the charge battery led!
                                What did I do wrong?
                                I already tried to remove CMOS battery, battery, charger, it simply doesn't power on.
                                Please HEEELLPP!!
                                Thanks.
                                Try Harder!
                                • highpulse
                                  i hate HP
                                  • May 2013
                                  • 1488
                                  • portugal
                                  if im not mistaquen your SIO chip is a nuvoton 781 , if after replacement machine worked , and after a while died again ,could be the SIO chip damaged , making your bios to get corrupted , try replace Sio chip , and reflash bios again , and let us know
                                  • Learn2Day
                                    • Jun 2013
                                    • 254
                                    • Portugal
                                    Thanks,
                                    But 1st, I don't have a BIOS programmer, and second i need help locating SIO chip.
                                    Try Harder!
                                    • lezsimply
                                      The Wanderer
                                      • 645
                                      • Philippines
                                      On pic 001, left side the big square one with many pins. close to hole H6502 and H6525. With marking NUOVOTON
                                      • Learn2Day
                                        • Jun 2013
                                        • 254
                                        • Portugal
                                        Thanks.
                                        Confirmed it's not SIO chip. Soldered last BIOS again and laptop turns on again, RAM error, etc..
                                        I need to flash BIOS but I don't have a BIOS programmer on me. Only thing it comes to mind is try a crisis recovery.
                                        Can anyone help me here?
                                        Thanks.
                                        Try Harder!
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • Focus2005
                                          HP OMEN 16-C0114NW – no image after replacing CPU Ryzen 7 5800H with 5 5600H and flashing BIOS
                                          by Focus2005
                                          Hello everyone.
                                          I have another HP OMEN 16-C0114NW laptop with serial number 5CD1501LJX. The original problem was as follows. The laptop could not load Windows and every time it threw a bluescreen - y - most often WHEA_UNCORRECTABLE_ERROR. The processor that was originally in it was AMD RYZEN 7 5800H MOBILE PROCESSOR - 100-000000295. I decided to replace it with a fully functional, used AMD RYZEN 5 5600H MOBILE PROCESSOR - 100-000000296, which I got from a donor board, on which it worked 100%. After soldering the processor, I also uploaded a new, fresh BIOS to it with the UBT2 program...
                                          05-01-2025, 05:41 AM
                                        • iZakre
                                          HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                                          by iZakre
                                          Hello everybody!
                                          To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                                          The thing is that I had installed TeamViewer and could log into the computer...
                                          02-19-2023, 02:27 PM
                                        • q2v5
                                          Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                                          by q2v5
                                          Lenovo T480s
                                          Model 20L8-S3TE00
                                          Board ET481-U10
                                          Chip MX25L12873F
                                          Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                                          2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                                          The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                                          08-15-2024, 10:40 PM
                                        • Neddsme
                                          Bios partially corrupted somehow and now warm boot doesn't work which is critical
                                          by Neddsme
                                          Hie.
                                          I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
                                          Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
                                          I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
                                          I managed to run Windows troubleshooting and...
                                          02-04-2022, 05:57 AM
