What capacitor
    What capacitor
    I have reballed the GPU and have 3 blown capacitors on a hp touchsmart with ratings 5v 820uf. 105C
    I have no capacitors in stock with that rating. Before I waste my time would 6.3v 1000uf do the job or can someone recommend a more apt set?
    Re: What capacitor
    820uf must be the same, voltage can be a bit higher, so a 6.3v 820uf or 10v 820uf is ok.
    6.3v 1000uf is not ok.
      Re: What capacitor
      5v is not a standard voltage rating. It could be 25v and you just don't see the 2.
      The standard values are 2.5v 4v 6.3v 10v 16v 25v etc
      Low ESR 1000uF would be fine I guess, 6.3v would also work if you're absolutely sure that capacitor is 5v or less.
      Maybe 5v is some series code or it's actually 25v and you simply don't see the voltage rating due to capacitor being very small?
      It would help if you could post some pictures.
        Re: What capacitor
        Originally posted by dellxps15 View Post
        820uf must be similar, voltage can be a bit higher, so a 6.3v/10v 820uf/1000uf is ok.
        6.3v 1000uf is ok.
        fixed that for you.
        Follow the white rabbit.
          Re: What capacitor
          sorry they are 4v 680uf 105c what can be used instead?
          thanks
            Re: What capacitor
            You should use polymer capacitor, 560-680uF.
            If you don't have polymer, you can use electrolytic but should use capacitors rated for higher voltage so that the ESR value would be closer to the value of the original capacitor. And up to 1000uF would probably be fine.
            CPC sells them in UK and relatively cheap, here's what I'd recommend :
            http://cpc.farnell.com/panasonic/eeu...10v/dp/CA07428
            http://cpc.farnell.com/panasonic/eeu...16v/dp/CA07425
              Re: What capacitor
              Thanks for your help guys!
