What capacitor
  • scooby01
    • Dec 2011
    • 28
    • uk
    What capacitor
    I have reballed the GPU and have 3 blown capacitors on a hp touchsmart with ratings 5v 820uf. 105C
    I have no capacitors in stock with that rating. Before I waste my time would 6.3v 1000uf do the job or can someone recommend a more apt set?
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: What capacitor
    820uf must be the same, voltage can be a bit higher, so a 6.3v 820uf or 10v 820uf is ok.
    6.3v 1000uf is not ok.
    • mariushm
      • May 2011
      • 3799
      Re: What capacitor
      5v is not a standard voltage rating. It could be 25v and you just don't see the 2.
      The standard values are 2.5v 4v 6.3v 10v 16v 25v etc
      Low ESR 1000uF would be fine I guess, 6.3v would also work if you're absolutely sure that capacitor is 5v or less.
      Maybe 5v is some series code or it's actually 25v and you simply don't see the voltage rating due to capacitor being very small?
      It would help if you could post some pictures.
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        Re: What capacitor
        Originally posted by dellxps15
        820uf must be similar, voltage can be a bit higher, so a 6.3v/10v 820uf/1000uf is ok.
        6.3v 1000uf is ok.
        fixed that for you.
        Follow the white rabbit.
        • scooby01
          • Dec 2011
          • 28
          • uk
          Re: What capacitor
          sorry they are 4v 680uf 105c what can be used instead?
          thanks
          • mariushm
            • May 2011
            • 3799
            Re: What capacitor
            You should use polymer capacitor, 560-680uF.
            If you don't have polymer, you can use electrolytic but should use capacitors rated for higher voltage so that the ESR value would be closer to the value of the original capacitor. And up to 1000uF would probably be fine.
            CPC sells them in UK and relatively cheap, here's what I'd recommend :
            http://cpc.farnell.com/panasonic/eeu...10v/dp/CA07428
            http://cpc.farnell.com/panasonic/eeu...16v/dp/CA07425
            • scooby01
              • Dec 2011
              • 28
              • uk
              Re: What capacitor
              Thanks for your help guys!
              • MORETTIGIAN
                by MORETTIGIAN
                Title:
                Description:
                Procedure performed:
                - Removed backplate
                - Reapplied thermal compound
                - Reassembled card
                09-18-2025, 12:14 PM
              • chth96
                Is it no harm to replace with capacitor without ripple current rating?
                by chth96
                When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                Rubycon YK DataSheet (b...
                04-19-2024, 05:19 AM
              • Prolog
                by Prolog
                12-01-2024, 08:27 PM
              • Adenitz
                Explanation of capacitor rating
                by Adenitz
                I'm reading an article about the "capacitor plaque" in early 2000s and I have found one sentence I cannot understand.
                The normal lifespan of a non-solid electrolytic capacitor of consumer quality, typically rated at 2000 h/85 °C and operating at 40 °C, is roughly 6 years. It can be more than 10 years for a 1000 h/105 °C capacitor operating at 40 °C.
                What this 2000h or 1000h means? Why 1000h capacitors have longer life span?
                12-26-2022, 12:36 AM
              • Per Hansson
                Motor run capacitor physical size vs voltage rating & measurements?
                by Per Hansson
                (TL;DR skip the first paragraph)
                I encountered my first dead motor run capacitor at a customer this week.
                For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                (Unless a servo motor makes more sense that is).
                But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                The pump would run but sometimes trip the 10A breaker.
                I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                Then it could...
                09-20-2020, 06:32 AM
